REW Forum
Anybody tried a USB-to-Serial adaptor?
Discuss Anybody tried a USB-to-Serial adaptor? in the Equalization | Calibration forum; Anybody tried a USB-to-Serial adaptor? Hello, Did anybody tried and succeded in using a USB-to-Serial adaptor on a laptop? I don't have any serial port ...
Views: 626 - Replies: 4
Old 12-16-06, 06:18 PM   #1
Alias: Xtrips
Loc: Israel
User: #4821
Since: Dec 2006
  xtrips is offline
Hello,
I don't have any serial port on my laptop but I do have the above mentioned adaptor and it works with other devices i am using it with.
Nevertheless when I try it with REW and my Tag Av32D it says the port is in use or no device detected.
I can keep on looking for a solution but I would like to know if i am on the right track, if REW supports this kind of RS232 port.
Thank you.
Old 12-16-06, 06:46 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Anybody tried a USB-to-Serial adaptor?
Does Windows think that it has a Comm1 or Comm2 when you have the adapter installed?
I would think if it does, then REW should see it on startup....
Never tried it myself though. John may have to comment on this..
Old 12-17-06, 07:48 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Yes, it should work, remember to select the comm port that the adaptor is set up to use in the REW Comms menu.
Old 12-17-06, 02:09 PM   #4
Alias: Xtrips
Loc: Israel
User: #4821
Since: Dec 2006
  xtrips is offline
Hello,
Well, no, it doesn't. I just tried through my docking station (which has a regular com port) and it was flawless. It seems there is problem with the adaptor solution, although the adaptor works perfectly well.
I am looking for somebody that tried that actually.
Thanks
Old 12-17-06, 06:35 PM   #5
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
I use a USB-serial adaptor (several as it happens). Some adaptors can end up on different ports each time you plug them in unless you configure them to use a specific port number, try looking at the properties of the adaptor in the Windows Device Manager and see if there is a setting to choose the com port number the adaptor should use.
