| REW Forum Problem settings input level in REWDiscuss Problem settings input level in REW in the Subwoofer Equalization | Calibration forum; Problem settings input level in REW REW detects no input control for my Indigo IO card
It seems that I get some feedback when I adjust ... |
| | #1 (Link) | |||
| Problem settings input level in REW REW detects no input control for my Indigo IO card It seems that I get some feedback when I adjust the volume control on my pre to get a proper level of pinknoise out from REW. I can't get a stable level when the feedback starts and I doubt it would be correct if I could I did a couple of searches but couldn't find anything relative in the archives TIA | |||
| | #3 (Link) | ||||
| Re: Problem settings input level in REW Quote:
brucek | ||||
| | #4 (Link) | ||||
No "monitor" option on the Indigo's console Well , at least I got passed the BSOD! I'll have to keep looking, or maybe, think of inexpensive USB solution Do you have any recommendations?? Thanks again Julien | ||||
| | #7 (Link) | |||
| Re: Problem settings input level in REW You need to click the monitor mute buttons for the analog in (below the monitor pan sliders) otherwise the record input is mixed directly back to the output. The card has no control for the record level, if you are using a mic to record you can adjust level using the mic preamp, if using an RS SPL meter you should be OK with the dB range set to 80. | |||
| | #8 (Link) | |||
| Re: Problem settings input level in REW OIC "Said the blind man" My thinking was that the "analog in" needed to be active for the SPL and measurement functions to work. Thanks for the Heads-up I'll have to see how far I can get tonight! Julien Last edited by Julien43; 12-19-06 at 04:58 PM. Reason: Left something out | |||
| | #9 (Link) | |||
| Re: Problem settings input level in REW I even think the manual talks about the feedback issue too ![]() http://www.hometheatershack.com/room...tml/index.html | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| ? on Setting the input level on BFD | kryolla | BFD Forum | 5 | 11-01-06 08:44 PM |
| My Final Hsu VTF-2 Subwoofer Settings Thanks to REW | geekwithfamily | Home Theater, Audio and Video News | 0 | 09-18-06 11:00 AM |
| input level, and roll off | eddthompson | REW Forum | 9 | 08-23-06 07:10 PM |
| Input Level Warnings | rsachs | REW Forum | 1 | 08-05-06 05:32 AM |
| Problem setting target level | jimsfield | REW Forum | 9 | 06-19-06 08:07 AM |
