| REW Forum Technics SH-8000Discuss Technics SH-8000 in the Subwoofer Equalization | Calibration forum; Technics SH-8000 Hi Guys, I'm new here and have a few questions
I have this Technics SH-8000 Audio Frequency Analyzer I bought ... |
| | #1 (Link) | |||
| Technics SH-8000 Hi Guys, I'm new here and have a few questions I have this Technics SH-8000 Audio Frequency Analyzer I bought in the early 80's and would like to know if anyone has any ideas on its use with the room eq wizard and the BFD thanks Josh | |||
| | #2 (Link) | |||
| | Re: Technics SH-8000 Hey josh and welcome to the Shack! I'm not familiar with that unit... is it merely an analyzer or does it have an eq with it, parametric or graphic, 1/3 octave, etc? REW is pretty much an analyzer in itself... of course it will do more than analyze and will do more than any other analyzer I'm familiar with. | |||
| | #3 (Link) | |||
| Re: Technics SH-8000 Hey Sonnie thanks and yes it is a warble tone generator with a calibrated mic and no it will not do anything even close to what the rew will do, awesome program i just ordered the Behringer 1124 and have installed the REW, its rejuvinated my interest in my sound system I run a Paradigm Servo 15 in a room thats 13wx18Lx12H and get a reasonable response, but i have some peaks in the 40 to 70 hz range that i'd like to tame I also have an old RS Analog meter, so i did a comparison between the response I got with that vs the Technics calibrated mic, but now sure if i'm doing it all correctly Go here for a pic of the Technics http://www3.tokai.or.jp/one-drop/page/technics.html Josh | |||
| | #6 (Link) | ||||
| Re: Technics SH-8000 Quote:
Sonnies excellent excel sheets have the RS meter cal file baked in under the compensated columns. You would have to enter the calibration file for your microphone into the technics spreadsheet to compare apples to apples. ![]() brucek | ||||
| | #7 (Link) | |||
| Re: Technics SH-8000 sonnie maybe the specs will help you to help josh. You can see the original version @: http://www11.plala.or.jp/se_ke5583/T...c/sh-8000.html I hope it helps I am not a mic-man but here it is from Japanese to English: Technics SH-8000 YEN29,800(1990年10月頃)Aroung 10/1990 Used with an equalizer for the compensation of soundstage deficiency in listening room 機種の定格 Specifications 型式Type オーディオ・フレケンシー・アナライザーaudio frequency analyzer 本体 <発振部> 発振信号 ワーブルトーン(変調周波数:8Hz)warble tone(adj. Freq 8Hz) 発振周波数 warble Frequencies 20、25、31.5、40、50、63、80、100、125、160、200、250、315、400、500、630、800、1k、1.25k、1.6 k、2k、2.5k、3.15k、4k、5k、6.3k、8k、10k、12.5k、16k、20kHz(測定ポイント:31)31 Band 周波数精度Frequency accuracy±6% 定格出力/出力インピーダンスOutput / output impedance 70mV/1kΩ <メーター部> 音圧測定範囲sound pressure Measurable range 35dB~105dB SPL(0dB=2×10-4μbar)(50dB~90dB間10dBステップ5レンジ切換)(Between50dB~90dB,10db step and 5 adjustable range) メーター応答速度meter reaction speed FAST:立ち上がりraise time350msec、立ち下がdown time400msec SLOW:立ち上がりraise time 550msec、立ち下がりdown time 2sec <総合> 電源 power 9Vバッテリー(S-006P×1)9V battery 電池寿命battery lifespan 10時間(連続動作時)10hrs continuous usage 外形寸法 Dimension 幅430×高さ53×奥行158mm (LxHxD) 重量 weight 1.0kg マイクロフォン MIC 型式 Type バックエレクトレットコンデンサー型Back Electret condenser type 指向特性 Operation mode 無指向性 non-directional 正面感度 Sensitivity -72dBV/μbar(1kHz) 周波数特性 Frequency Response 20Hz~20kHz 最大入力音圧 Maximum Input 110dB SPL(0dB=2×10-4μbar) 出力インピーダンス Output Impedance 600Ω不平衡形Unbalanced 電源 Power 1.5V(SUM-3×1) 電池寿命 Battery Lifespan 1500hrs時間(ナショナルハイトップ使用連続動作時)continuous usage コード長さ Cord Length 4m | |||
| | #8 (Link) | |||||
Am I misunderstanding this? Quote:
He did it... blame it ALL on him... ![]() I guess my thinkin' (pessimistically) would be why even bother with the Technics? You got the BFD coming to you and REW at your fingertips with an RS meter... I'd just use those. I would think it would all be superior to the Technics anyway. Now if you are just wanting to play around with the Technics for the heck of it... that's a different story. | |||||
| | #9 (Link) | ||||
It's Frequency Response shows as 20Hz to 20kHz. That's acceptable, but as Sonnie says, why not use the RS Meter... ![]() brucek | ||||
| | #10 (Link) | |||
| Re: Technics SH-8000 thanks for all the response guys, the sh-8000 does generate tones 20 to 20000, but since i don't know what the calibration is for the mic that comes with it, i'm just gonna use the rs meter i'll post what i come up with when i get my BFD | |||
| | #11 (Link) | |||
| Re: Technics SH-8000 Dear Sonnie, I do not own the sh-8000. I think that you have misunderstood my translation. I believe that'sound pressure Measurable range 35dB~105dB SPL ' means that the meter is able to measure Sound Pressure Level (SPL) from 35db-105db The statement did not mention anything about measuring FREQUENCY(Hz). I believe that the sh-8000 is able to measure Frequencies in the range of 20Hz-20KHz. | |||
