When I am taking measurements of my home theater should I place the mic in the primary listening position with the mic pointed towards the ceiling (90 degree angle)?
The short answer for subwoofer measurements is, it doesn’t matter.
If you’re doing full-range measurements (your main-channel speakers), the short answer is, you only point the mic towards the ceiling if you’re using a 90-degree incident (vertical) calibration file.
Horizontal orientation with the mic on-axis to the sound source (0-degrees incident) has been the traditional method for full-range,
free-field measurement, where the room was an open space relatively free of reflections. However, that’s mainly because most stand-alone RTAs (which until several years ago was about the only thing available) came with mics that were calibrated for on-axis measurements.
Some RTA manufacturers offered the option of 90-degree orientation for
random incident measurements (aka diffuse field), where the sound arrives from all directions more or less simultaneously, with equal probability and level. In other words, an exceedingly reverberant environment. Random-incident measurements required a different capsule for the measurement mic (which the manufacturer made available), for reason of the specific calibration as well as a housing better suited for 90-degree orientation.
That just refers to the mic’s position during its calibration, however. Everything I’ve seen for actual “in the field” measurements says the standard protocol for horizontal (on-axis) measuring is 20 degrees, and 70 degrees for vertical (i.e., angled slightly forwards towards the sound source). This may have something to do with compensating for interference from the mic’s housing with the sound waves, I forget exactly why.
The ready availability these days of mics with 90-degree calibration certainly opens up more measurement options. Others have their opinions, and maybe they’ll weigh in, but mine is that you will generally get the best results with on-axis measurements. It should be a no brainer to figure out that the home theater environment, while certainly not totally free of reflections and reverberation, more closely resembles a free-field environment than a random-incident environment.
Vertical orientation may add more upper-frequency information from ceiling reflections than you’d get with on-axis, and as such will probably influence what the RTA displays. How much so will depend on your particular room – how “live” it is, the height of the ceiling in relation to the distance between the sound source (speaker) and measurement mic (i.e. inside or outside the “first reflection” zone), etc. Even though the ECM8000 is omnidirectional, its capsule is rather large for a measurement mic. As a result, its off-axis response (compared to on-axis) starts skewing as low as 2 kHz. So differences >2 kHz are what you might see with horizontal vs. vertical readings. (Smaller-capsule omni mics typically retain uniform 0 vs. 90-degree response at least an octave higher.)
