REW ForumDiscuss Can't get any output using REW Please HELP!! in the Equalization | Calibration forum; Can't get any output using REW Please HELP!! You guys must get tired of troubleshooting a bad set-up!! I can not get any output when I try to ... |
Views: 800 - Replies: 18
| Can't get any output using REW Please HELP!! You guys must get tired of troubleshooting a bad set-up!! I can not get any output when I try to set the Measurement Level in REW I'm trying to get the signal to my pre amp so I can get a measurement of my mains speaker bass response What is strange is that when I shut down the computer with everything set to do this, the system "shut down" wave is heard through the correct mains speaker I know I have something wrong, but can't figure out what it is ![]() I have chose "Speaker" for output. I have also left it at the default "choose output" I have no idea where to look next Thanks much Julien | ||||
| | #3 | |||||
| Re: Can't get any output using REW Please HELP!! Quote:
Julien | |||||
| | #6 | ||||
| Re: Can't get any output using REW Please HELP!! And when you get to the final step in the Set Measurement Level do you see the picture below with the VU meter showing green, and the Wave at 1.000 and Output at 0.500 and able to adjust the level to something like -12dB as shown? Yet there is no signal going to your receiver? ![]() brucek | ||||
| | #7 | |||||
If I shut down the computer I do hear the "System Shut-down" tones through the proper speaker ![]() | |||||
| | #8 | |||||
How about the Windows mixer when REW is running. Does the playback mixer look like this for Volume and Wave (unmuted and with the same Volume shown in REW)? In fact, raising and lowering the slider should reflect on the REW picture I showed before. Clicking the Mutes will reflect in REW too? ![]() brucek | |||||
| | #9 | |||||
There are some minor differences | |||||
