| REW Forum Connecting X-Fi Fatal1ty to the SPL and REW...Discuss Connecting X-Fi Fatal1ty to the SPL and REW... in the Equalization | Calibration forum; Connecting X-Fi Fatal1ty to the SPL and REW... Hi!
I decided to play with this yesterday and wanted to keep it very simple. I used and RCA (component ... |
Views: 740 - Replies: 1
| Connecting X-Fi Fatal1ty to the SPL and REW... Hi! I decided to play with this yesterday and wanted to keep it very simple. I used and RCA (component cable) to go from the SPL meter to my X-FI front panel's Line input. Will this be enough to make it work? I am trying to measure my main speakers bass performance as I am dont like the sub for music. I tried following the guide but somehow I couldnt figure things out. Perhaps there is a for dummies version of the guide? Regards | ||||
| | #2 | ||||
| Re: Connecting X-Fi Fatal1ty to the SPL and REW... I guess your X-FI's outputs already run to your main speakers? If so, it should work OK, work through the instructions step by step and post here if you get stuck at some point. | ||||
