Connecting X-Fi Fatal1ty to the SPL and REW... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
REW Forum
Discuss Connecting X-Fi Fatal1ty to the SPL and REW... in the Subwoofer Equalization | Calibration forum; Connecting X-Fi Fatal1ty to the SPL and REW... Hi! I decided to play with this yesterday and wanted to keep it very simple. I used and RCA (component ...
Old 01-03-07, 10:02 AM   #1 (Link)
Alias: Shaolin95
User: #3303
Since: Oct 2006
shaolin95 is offline
Hi!
I decided to play with this yesterday and wanted to keep it very simple. I used and RCA (component cable) to go from the SPL meter to my X-FI front panel's Line input. Will this be enough to make it work? I am trying to measure my main speakers bass performance as I am dont like the sub for music. I tried following the guide but somehow I couldnt figure things out. Perhaps there is a for dummies version of the guide?
Regards
Old 01-03-07, 05:20 PM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Connecting X-Fi Fatal1ty to the SPL and REW...
I guess your X-FI's outputs already run to your main speakers? If so, it should work OK, work through the instructions step by step and post here if you get stuck at some point.
Similar Threads
Help! REW RS SPL correction seems inverted? Tommy Angelo REW Forum 1 11-13-06 02:52 PM
How to make all this work (SPL to REW to BFD) help rlammi REW Forum 87 08-10-06 09:10 PM
corrections for M-Audio and not enought SPL from REW UNICRON-WMD REW Forum 7 08-05-06 08:53 PM
Newbie question connecting sound card purcellt REW Forum 2 07-17-06 07:10 AM
RS Digital SPL meter and RCA output with REW Dent SPL Meters | Mic's | Calibration | Sound Cards 3 05-07-06 07:01 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
