| REW Forum Calculating Freq Response, never ending?Discuss Calculating Freq Response, never ending? in the Subwoofer Equalization | Calibration forum; Calculating Freq Response, never ending? Looks like I spoke too soon last night on my mac post. Now I am having issues...
After running the ... |
| | #1 (Link) | |||
| Calculating Freq Response, never ending? Looks like I spoke too soon last night on my mac post. Now I am having issues... After running the speaker calibration, the app starts "calculating frequency response". Figured all was well, and I went to bed. This morning it was STILL running. So I try it in parallels, wow no go there. There is obviously some serious issues running it that way. So I try on a mac mini I have, but the response appears corrupted. Tried the java 6 beta version available on ADC. No luck, the curve is a bit smoother, but still not right. So I am now in bootcamp on my macbook pro (c2d), figured we would get to the root of the problem this way. I have line out plugged into line in and run the soundcard measurement. The response is much more linear than either in osx or parallels. I get a bit of a warble beginning above 10khz, but it appears to be +-2db, so probably acceptable. Then "calculating frequency response" pops up. An hour later it is still burning a hole in my screen. What gives? Is this actually a problem on MBP systems no matter which OS they are running? I must be missing something. Java 1.5 and 1.6 have been tried... | |||
| | #2 (Link) | |||
| Re: Calculating Freq Response, never ending? There might be a clue in the log files in your home directory, they are named roomeqwizardx.log.txt where x is 0..9, the lowest number is the most recent startup. However it is probably best to wait for the new version and go from there, I've run it on a Mac Mini and it worked OK but there were clicks in the generated audio, so work to be done on that - no crashes or hangs though. | |||
| | #4 (Link) | |||
| Re: Calculating Freq Response, never ending? BTW: is there any way to output the recorded signal to a wav file? I suspect there are not only clicks in the produced signal, but in the recorded signal as well. Randomly I will get the "clipping detected" message even though I heard nothing in the playback and the inputs are set well below clipping. | |||
| | #6 (Link) | |||
| Re: Calculating Freq Response, never ending? I am using Room EQ Wizard on Windows XP with Java 1.6.0 and I get the same problem: Stuck on "Calculating frequency response...". There is nothing of note in the logs. Any ideas? John | |||
| | #7 (Link) | |||
| Re: Calculating Freq Response, never ending? Just fyi, even though it says "calculating freq response" the calculation appear to be done. It just has the notification box up. I have duplicated it with 1.6 under both xp and os x on my macbook pro. I would use the old thinkpad for measurement with java 1.5, but the response curve is a nice constant line from... 45-8khrz. Nothing at all above or below Talk about a bad sound card! | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Behringer UB802 response | brucek | SPL Meters | Mic's | Calibration | Sound Cards | 6 | 11-20-06 07:02 AM |
| Response graph | Blackwidow | REW Forum | 23 | 11-03-06 01:51 PM |
| New Sub: Monolith Response, any thoughts? | 3ll3d00d | REW Forum | 6 | 10-23-06 09:11 AM |
| IB in room response graphs | brandonnash | DIY Subwoofers - Infinite Baffle | 7 | 09-22-06 08:56 AM |
