| REW Forum Room EQ Wizard unhappy after Measure Soundcard ResponseDiscuss Room EQ Wizard unhappy after Measure Soundcard Response in the Equalization | Calibration forum; Room EQ Wizard unhappy after Measure Soundcard Response Downloaded V3.29 this afternoon; decided to try a built-in laptop soundcard
in spite of only Mic in and Headphone out; ... |
Views: 708 - Replies: 4
| Room EQ Wizard unhappy after Measure Soundcard Response Downloaded V3.29 this afternoon; decided to try a built-in laptop soundcard in spite of only Mic in and Headphone out; got a response very similar to: http://www.hometheatershack.com/room.../realteksc.jpg .. but when subsequently trying to verify the calibration, selecting and deselecting C weighting MADE NO DIFFERENCE. Manually resetting the upper sweep limit to 200Hz had no effect; sweeps ran to 20kHz or so. Selecting and deselecting C weighting is effective after quitting REW, restarting and loading the saved soundcard calibration, so it is an easy bug to work around. Windows XP SP2 and J2SE Runtime Environment 5.0 Update 10. BTW, I made Dell D520 Mic input useful by putting an 8uF non-polarized cap in series with an 82K resistor, with a 10K resistor to ground at the other end. | ||||
| | #2 | ||||||
| Re: Room EQ Wizard unhappy after Measure Soundcard Response Quote:
brucek | ||||||
| | #3 | |||||
| Re: Room EQ Wizard unhappy after Measure Soundcard Response I had and it was; response was nominally flat; it was Meter C Weighting that was being ignored. Quote:
when I get a BFD and calibrated mic. Meanwhile, for scooting around and making coarse corrections by speaker placement and crossover adjustments, etc, it's handy to involve as little equipment as possible. REW shows over 60dB between lowest sub sweep response and no signal, so I'm happy. | |||||
| | #4 | ||||
| Re: Room EQ Wizard unhappy after Measure Soundcard Response I have not figured out a button sequence to make it use a fresh measured response without first exitting and restarting Room EQ Wizard; save and load does not suffice. | ||||
