| REW Forum New Soundcard drivers gives REW an error.Discuss New Soundcard drivers gives REW an error. in the Subwoofer Equalization | Calibration forum; New Soundcard drivers gives REW an error. Hey guys, I have a little error pop-up whenever I try to select the audio input source. It reads "unable ... |
| | #1 (Link) | |||
| New Soundcard drivers gives REW an error. Hey guys, I have a little error pop-up whenever I try to select the audio input source. It reads "unable to access the selected device due to line with format PCM_SIGNED 48000.0hz,16 bit, 4 bytes/frame,little-endian not supported. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #2 (Link) | |||
| Re: New Soundcard drivers gives REW an error. Problem solved. My soundcard was set up for "high sample rate" and it never worked in this setting. I changed it back to normal 2-channel. If you don't have a BFD for your sub, get one fast! If you don't have REW, get it now! | |||
| | #7 (Link) | |||
| Re: New Soundcard drivers gives REW an error. Exocer, I have the same error message. Did you adjust the sampling in REW or the menu of your sound card (my does not have that option)? Thanks- Greg AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo Last edited by gacole2000; 06-18-06 at 08:00 AM. | |||
| | #9 (Link) | |||
| Re: New Soundcard drivers gives REW an error. Thanks Mike. No luck :-( AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
