Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
Donations Reviews Vendors
MiniDSP: Digital audio Signal Processors (DSP) engineered to fit a wide range of applications.
Views: 783 - Replies: 7
Old 07-09-10, 05:16 PM   #1
Since: Jun 2010
  mkedda is offline
I started this thread.
20hz to 80hz sweep, sound from center channell
When I run the test in the picture. I have sound coming from my center channell. How can that be?
I have all speakers set to small and crossover set to 100hz.
Old 07-09-10, 05:25 PM   #2
Since: Jun 2010
  mkedda is offline
Re: 20hz to 80hz sweep, sound from center channell
As a side note, what do you gain from this test? Can you capture and graph it?
Old 07-09-10, 05:40 PM   #3
Wayne A. Pflughaupt's Avatar
Katy, Texas
My Photo Gallery
You hear sound coming from your center channel because you have Dolby Pro-Logic engaged. Turn off all the receiver’s processing, so that you hear the sound in the left and right speakers.
Nothing I can think of.
Old 07-09-10, 07:18 PM   #4
Bill
Since: Sep 2009
Austin, TX
  laser188139 is offline
As I wrote to you yesterday, the high and low -3db cutoffs you see in that screen are just that, the points at which the rolloffs begin. When you run your mouse over the sub cal button, the pop-up help information indicates that the REW rolloffs are -12dB/octave. So its signal is down ~12dB as high as 160Hz, well above your crossover. So I'm not surprised you hear something from other speakers.
As Wayne wrote, REW is normally sending a 2 channel signal to the AUX input on the receiver. If you are hearing something from the center speaker, you must have some Dolby or surround mode enabled. If you are hearing something only from your center speaker and not the other satellites, that would result from Dolby Pro-Logic mode.
Bill
Old 07-10-10, 12:13 PM   #5
glaufman's Avatar
Greg
Since: Nov 2007
NY
My Photo Gallery
  glaufman is offline
When Bill says "sending a 2 channel signal" I believe he means it's meant for either L or R channels (and sub) and not meant for the C channel, just to clarify, I don't think he means to plug in both L and R channels at the same time... normally...
-Greg
Don't worry... nothing new here, I've already made that mistake. Trust me.
Old 07-10-10, 10:41 PM   #6
Bill
Since: Sep 2009
Austin, TX
That's a good point, Greg. For Wayne's suggestion, that sound is coming from the center channel instead of the left/right channels to work, wouldn't both channels have to be fed? So it sounds to me that the current connection is using a splitter to drive both left and right. And implicitly in your observation is that, if only the left or right were driven, the sound should be in only the left+sub or right+sub, not center+sub.
Bill
Old 07-12-10, 11:53 PM   #7
glaufman's Avatar
Greg
Since: Nov 2007
NY
My Photo Gallery
  glaufman is offline
You're probably right Bill. The only other scenario I see is if it was mistakenly connected to the C channel of the analog multi input...
But even in this scenario of both L and R were being driven, there wouldn't be output in the C channel unless surround processing was activated. There's no C channel in stereo mode.
-Greg
Old 07-12-10, 11:55 PM   #8
glaufman's Avatar
Greg
Since: Nov 2007
NY
My Photo Gallery
  glaufman is offline
I've often toyed with the idea of looking at my C channel's response this way, by feeding both L+R and using Prologic. And inverting one to feed the surround channels, even though I/we have 2 that would be getting a mono signal... you know me, I just like to play... more to the point, I like putting the ideas in other people's heads and getting THEM to play...
-Greg
 Reply     Post New Thread     Back to Top of Page
20hz, 80hz, center, channell, sound, sweep
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
