REW Forum
Very Low Level on Calibrated Mic, Please Help...
Discuss Very Low Level on Calibrated Mic, Please Help... in the Equalization | Calibration forum; Very Low Level on Calibrated Mic, Please Help... Hi Folks, I am having problems getting an accurate reading due to low input levels. I am doing some speaker ...
Views: 1226 - Replies: 6
Old 01-21-07, 06:50 PM   #1
New Member
Alias: SmX
User: #2676
Since: Sep 2006
  SandmanX is offline
Arrow Very Low Level on Calibrated Mic, Please Help...
Hi Folks,
I am doing some speaker testing with REW. For a soundcard I am using the Creative Soundblaster Live External 24 as recommended by this site. I am using the EMM8 electret condenser microphone and
a MP-1r microphone pre-amplifier from rivesaudio dot com
I follow the instructions in the help section and still the same occurs. To get an SPL reading I use the Radio Shack Digital SPL Meter and adjust the level to 75 db using the Creative mixer. I have the mic pre-amp set to full volume and everything else as well and I keep getting a -36 db reading on the input of REW and a warning message evertime I run a sweep.
Any thoughts?
Thanks
Ruben
Old 01-21-07, 06:59 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Very Low Level on Calibrated Mic, Please Help...
Are you using a stereo plug on the input line-in of the sound card? and if so, are you selecting the correct channel?
I am using the EMM8 electret condenser microphone and a MP-1r microphone pre-amplifier from rivesaudio dot com
Do you have a calibration file for this mic or is it perfectly flat?
Old 01-21-07, 07:47 PM   #3
New Member
Alias: SmX
User: #2676
Since: Sep 2006
  SandmanX is offline
brucek wrote: View Post
Hi Brucek,
The the soundcard input wire is a mono 1/8" jack that connects to the RCA output of the mic preamp.
I tried using the left and right channel selection in the REW input and only one channel has a signal coming in which is the one I am currently using with the low level.
The Mic comes with a calibration file which I loaded into REW before I did anything else.
Thanks
Ruben
Old 01-21-07, 08:00 PM   #4
Alias: brucek
User: #6
That has to be a stereo plug because the soundcards jack is a stereo jack.
You only use one channel of the plug, but it still has to be stereo.
You need one of these two types of adapters. I like the wired one because the other is so bulky. They are stereo 1/8" to two channels split.
Get one of these and we'll carry on from there.
Old 01-22-07, 11:19 AM   #5
New Member
Alias:
User: #2744
Since: Sep 2006
  deadkenny64 is offline
I am using a stereo adapter with a RS meter as the mic with the same USB sound card and got the same error message. I switched the meter from 80db to 70db and got it to take after 2 more tries. It seems to be just barely enough signal on the line in to work with all sliders maxed. When I was using my laptop sound card (mic input) it seemed to have plenty of signal level.
Old 01-22-07, 12:39 PM   #6
Alias: brucek
User: #6
Mic inputs are unsuitable to use with REW....
Old 01-22-07, 03:19 PM   #7
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
SandmanX wrote: View Post
That setup works well, though the MP-1r produces a bit of noise at very low frequencies. Set the Input Volume to 1.000, to set the gain on the MP-1r play a speaker cal signal at 75dB SPL and aim for around -20dB rms input level on REW (it's easier to set the levels with speaker cal than sub cal) or look for the -10dBV LED on the MP-1r to start flickering - should find the level control is at about 2 or 3 o'clock.
Something is wrong in the setup, with the SB Live 24-bit External and the Line In/Mic-In slider set to full (1.000) you should see around -21dB rms with the RS meter set to the 80dB range when a 75dB SPL cal signal is playing.
