REW Forum
M-Audio Mobile Pre -- calibration ?
Discuss M-Audio Mobile Pre -- calibration ? in the Equalization | Calibration forum; M-Audio Mobile Pre -- calibration ? I searched the old threads but am still a wee bit confused on the final setup using an M-Audio MobilePre ...
Views: 914 - Replies: 11
Old 01-23-07, 09:19 AM   #1
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
I searched the old threads but am still a wee bit confused on the final setup using an M-Audio MobilePre and a ECM8000 mic.
Wiring:
Obviously the mic goes to the sound card with an XLR cable. Now, how to go from the sound card to my system? Will I need to make some sort of mono 1/4" to RCA cable?
Also, how to run the calibration? Should I just use the XLR mic cable and go from in-to-out on the same channel? I seem to remember somebody getting weird feedback in the .cal file from that.
Thanks for the help.
A
Old 01-23-07, 10:57 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: M-Audio Mobile Pre -- calibration ?
The M-Audio has both a stereo 1/8" line out and also separate 1/4" left and right line-out. Easiest to use the 1/4" mono to RCA I would think. Plug the RCA into your receiver with a Y-cable to CD or AUX..
I don't know what people are using for the loopback on this device. Perhaps someone who owns this unit can comment.
Old 01-23-07, 01:15 PM   #3
Alias: Boyce
User: #480
  boyce is offline
Anthony wrote: View Post
I don't have M-Audio Mobile, but I did try M-audio Firewire 400, I put cable from ch1 unbalance output to mic 1 XLR input, it work for room EQ, but it doesn't work for ETF /RPlusD, finally I change to M-audio transit, it work for both.
Old 01-23-07, 07:54 PM   #4
Alias: brucek
User: #6
  brucek is offline
A couple problems with this is that the mic amp provides very high gain (since a low output mic is usually feeding it), so the level may be hard to control.
The other problem is that there is 48volts DC phantomed on the XLR jack to provide voltage for a microphone. I suppose the line output stage is capacitively coupled, but it doesn't seem like a good practice to me.
I admit I don't know how to produce a cal file for this soundcard.
Perhaps John M has used one of these.. Any suggestions?
Old 01-23-07, 08:34 PM   #5
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
I tried it two ways:
stereo 1/8" out to stereo mic in. Looked okay, but with some feedback at the top end.
Mono, 1/4" plug channel 2 out to in. Looked great. Mostly flat with a slight roll off on each end. That seemed to work best for me.
The XLR mic is fine with the phantom power. I upped the reference sound to 78dB and get -12dB on the input channel during level setting. Sweeps look good so far.
At 75dB and full gain on the input channel, I was getting just below -18dB and the error message, but so far things seem to work. When in doubt, trial and error
Thanks for the input, guys.
Old 01-24-07, 11:41 AM   #6
Alias: Boyce
User: #480
  boyce is offline
adjust the on board gain control switch down.
Turn off on board phantorn power switch.
Old 01-24-07, 11:54 AM   #7
Bronze Supporter
Alias: jack
basementjack's Avatar
Loc: Chicago Suburbs, IL USA
User: #2649
Since: Sep 2006
  basementjack is offline
I have a moble pre, and I used a 1/4 inch to 1/4 inch 1 foot patch cable I got from a music store - it was long enough to reach from front to back (it has 90degree connectors)
I have not used it with REW yet, but I'll try to in the next day or so. (I also have an M-Audio fastrack pro, which is what I played with last night)
- Jack
- Jack
Old 01-24-07, 01:09 PM   #8
Alias: brucek
User: #6
  brucek is offline
Yep, good idea - smart. (I admit I don't know the soundcard in question very well)
Yeah, but then you are not creating a compensating calibration file for the signal path in use when you measure. You have bypassed the mic preamp which may well have a horrible response that you need corrected (that's the purpose of the cal file). The full loopback ensures that the cal file is providing an inverse correction to the output and input path used when measuring.
Old 01-24-07, 09:45 PM   #9
Bronze Supporter
Alias: jack
User: #2649
Since: Sep 2006
True Bruce, i wonderd if there wasn't a way to run the line out to mic in, but feared it would overpower it, Plus isn't the mic in balanced?
- Jack
Old 01-24-07, 10:14 PM   #10
Alias: brucek
User: #6
  brucek is offline
Yep, but isn't there both a line-out balanced and unbalanced available..... just connect the balanced line-out to balanced mic in, and turn off the phantom power and adjust the gain until you are able to get a cal file....... that's my take anyway.
Old 01-24-07, 11:24 PM   #11
Alias: Anthony
Anthony's Avatar
Loc: Virginia
User: #2921
Since: Oct 2006
  Anthony is offline
Next time I order from Parts Express, I'll get a stereo 1/4" phono and make an XLR to balanced phono cable (still have plenty of cable and XLR connectors) and compare the calibration files. Sadly that will be a couple of weeks, but I'll be sure to put that on the order.
Old 01-25-07, 12:02 AM   #12
Bronze Supporter
Alias: jack
User: #2649
Since: Sep 2006
The Mobile Pre USB does not have balanced outputs.
So it would seem that the best we can do to calibrate this device is to go unbalanced out to unbalanced in.
- Jack
