| REW Forum A few unanswered questionsDiscuss A few unanswered questions in the Equalization | Calibration forum; A few unanswered questions Hi - I'm just getting started and have spent the past day soaking up as much great info is available ... |
Views: 651 - Replies: 11
| A few unanswered questions Hi - I'm just getting started and have spent the past day soaking up as much great info is available here and in the help file and AVS - great stuff. Some quick background. I'm interested in using BFD and REW only to smooth out my sub. Currently I measure this (adjusted for dB / RadioShack SPL levels): 16 Hz 82 dB 20 Hz 82 dB 25 Hz 86 dB 31.5 Hz 92 dB 40 Hz 80 dB 50 Hz 74 dB 63 Hz 75 dB 80 Hz 70 dB So my main goal is to smooth out the 25-35hz range and fill in from 50-80hz. Here are some remaining questions I have after going over all this: 1) I read that target response allows selection of 12 or 24dB/octave crossover slopes. What does it default do and where can this be changed? I have a HSU sub - am I correct to use 24dB? 2) Am I correct that the best thing to do is to send the output from the sound card into the receiver, and let it apply its processing and crossover to the signal for my measurements? I then tell REW to use Full Range. Correct? 3) My fronts are set to Small and crossover is 80hz. The fronts are rated down to 32hz so they still put out some good base well below 80hz (because of the sloped cutoff). When I measure this 20-80hz range I want REW to take into account the bass from BOTH the front left AND right channels. Therefore I take it I need to feed both channels from the sound card output into my receiver, right? I ask because surprisingly the docs and diagrams only show hooping up the left OR right. Why would someone want to do this and leave the bass out of one of the fronts from the measurement if they are measuring Full Range? 4) Is there any type of test I can perform on my sound card (or any things I can look for in its software/drives) to see if it supports full duplex? For example perhaps there is only a certain setting in the software options under Windows sound controls available for cards that support full duplex? 5) Will REW run ok with the new Java 6 available from Sun? 6) Does anyone know of any higher end A/V receivers that have built in calibration capabilities and editable parametric EQ data specifically for the low bass say 20-100 hz? I could us a new receiver, so if so, it may be easier to just do all the tweaking in the receiver and not have to use the BFD? Thanks! | ||||
| | #2 | |||||||||
| Re: A few unanswered questions Quote:
Yes Quote:
| | #3 | |||||||||
Why full range? Select subwoofer to equalize a subwoofer. Quote:
brucek | |||||||||
| | #4 | |||||
So in that case am I correct to assume that I should feed both right and level RCA plugs into the receiver? I know bass is non-directional, but if I don't feed them both then I'm thinking I'd only have bass coming out of one of the fronts and the sub, instead of both fronts and the sub which is what I need to be more like the real system running. Is this a correct assumption? | |||||
| | #5 | |||||
So I figure I might as well just address the whole system i.e. full range from the gecko. Is this not a valid approach? Thanks. | |||||
| | #6 | |||||
brucek | |||||
| | #7 | ||||||
Then once I am happy with that, add in the fronts and measure based on Full Range, and make any necessary adjustments based on that? The only thing I'm thinking is that why not just calibrate everything together at once. Ultimately it seems like I'll just wind up with the same settings but following the way you suggest I'll have to calibrate twice to get there. Would it not be more direct to just do it all at once? Obviously I'm missing something or you wouldn't be recommending that approach - so I'm just trying to better understand the logic here. Quote:
Obviously I could just disconnect them. However I remember reading that it is very bad for an amplifier to be sending signals out to a speaker which is not attached. Will this be ok when I'm outputting 80dB to left/center/right and nothing is hooked up to it? If not then how do I isolate those channels so I can have the sub only play? brucek[/QUOTE] | ||||||
| | #8 | ||||
| Re: A few unanswered questions I'm not understanding why you have to use a Y cable if you want to feed the left and right input of the receiver. You are basically saying to take one side of the soundcard's output (let's say the right channel) and split that signal with your Y cable so that the right channel feeds into both the left and right input of the receiver. The left and right output from the soundcard is supposed to carry identical signals so why can one not feed the left and right soundcard output into their respective inputs in the receiver? | ||||
| | #9 | |||||
| | #10 | ||||||||
brucek | ||||||||
| | #11 | ||||
| Re: A few unanswered questions REW puts the test signal on both left and right outputs, so you could just connect a stereo lead from soundcard to receiver. | ||||
