| REW Forum Creating my first house curveDiscuss Creating my first house curve in the Subwoofer Equalization | Calibration forum; Creating my first house curve After equalizing my sub I agree with the consensus that it makes the sub sound pretty dull, and that defining ... |
| | #1 (Link) | |||
| Creating my first house curve After equalizing my sub I agree with the consensus that it makes the sub sound pretty dull, and that defining a house curve is in order! After reading through the stick and REW help files I have a few questions please: 1) In the sticky it talks about the approach of using the -15dB filter at 366Hz to create a house curve. However this seems like a different approach compared to the "house curve" functionality built into REW. Which approach is best used under which circumstances? 2) Its obvious to me how the -15dB 366hz shelving filter works. But I don't readily see how the REW house curve function gets translated to the BFD. I see how you set up the house curve file for REW. But what exactly is REW doing with this information when it imports it? Does it create additional filters at various points that create the necessary cuts or something? 3) There seems to be three different types of house curves. On type is a fairly linear drop off from the 20-100hz range. The other type is more curved as shown with the 366hz filter. And yet another approach I've seen posted is where bass from say 20-35 hz is several dB higher, and then it drops several dB but flattens out from there (rather than sloping away as the frequency gets higher). Is there a consensus for what tends to work best or what type most peopel prefer? I am interested for MOVIES only - do not care how music sounds except of course for music that plays as a movie soundtrack. What types of sound characteritics do these various house curve styles have? | |||
| | #2 (Link) | ||||
| Re: Creating my first house curve Quote:
Don't read more into the house than it is. It is simply modifying the standard REW target line with your own ideas of what you want the response to look like. That's basically it. Realize that this extra lift you are programming in doesn't usually come for free. Unless you have some fortunate room gain, then you will have to raise the wholesale subwoofer level with the sub amplifier and then cut the response down to the house curve. You can lose lots of headroom. Look at this plot of a standard target and then one where I add a housecurve.txt file with the simple parameters shown. The yellow shows the extra output I am going to need from my sub to pull it off. Where is that gain going to come from? Are you going to add gain filters? No, that's a bad idea (that a lot of people haven't figured out yet). You will need to turn up your sub amplifier 5dB and then use filters to cut down to the target.. house_combined.jpg brucek | ||||
| | #3 (Link) | |||
| Re: Creating my first house curve OK, I was thinking that you get your normal target done, then apply a house curve, and then it somehow transformed the existing filters. So do I have this correct in that basically what I need to do is to start over, except this time I alter the target using the house curve before I start applying filters. Then I have it apply the filters, optimize them, and tell it to adjust the gains to the target. Before I get started turn the sub up so that it measures 80dB at say 25 hz, and run the Measurements and adjustments from there. Do I have this right? The other question is what level do you then use when you calibrate your sub to fit with your mains? I assume you aim to have say 50hz to be at 75dB while letting the lower end run hot? | |||
| | #4 (Link) | |||||
In my plot above I used two entries. I started the house curve at 80Hz (the crossover) with a zero. Then I raised the level by +5db up to 30Hz. That's it. You can do anything you want with as many entries as you want. Play around with it. Quote:
Wanna see it? I like how it sounds, but that's just me. My point is, there is no correct answer. FULL_RANGE_WITH_FILTERS.jpg brucek | |||||
| | #5 (Link) | |||
| Re: Creating my first house curve Interesting. What is your xo point? What params did you use to create this house curve? Also am I correct that the option that says something like "apply PK gains" in the filters part of the window is what will force REW to bend the response to follow the target (even if there are no peaks there)? | |||
| | #6 (Link) | |||||
30 5.0 40 3.0 50 1.0 60 0.0 Quote:
brucek | |||||
| | #7 (Link) | |||
| Re: Creating my first house curve For my situation, room gain gave me a natural rise in the low frequencies: (this graph shows response with bass traps in the room, sub + mains, sub near front right corner along right wall) ![]() So I cut down the peaks up higher and let the room gain give me a nice curve below 30Hz. I listen to a lot of music, probably more than I watch movies (although TV and video games figure in as well), so I didn't want the bass to be boomy and over-powering for music. Most bass in music is above 30~35Hz, so this curve gives me a nice rise in the deeper bass. ![]() | |||
| | #8 (Link) | |||||
As brucek notes, with REW people now tend to equalize along the target line. However, if you happen to have relatively flat response above the point where the target line drops, it makes more sense to apply the shelving filter than add a bunch of filters between 30 and 100 Hz. For instance, referring to cyberbri’s equalized graph – notice how flat his response is between 30-80 Hz. If he decided he wanted a steeper slope, it would make the most sense to apply a single shelving filter. Quote:
Regards, Wayne | |||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Sub level post house curve | jaz123 | REW Forum | 3 | 12-29-06 10:32 AM |
| House Curve Options | Ayreonaut | REW Forum | 21 | 11-21-06 08:13 AM |
| Target response / House curve | sonata31 | REW Forum | 6 | 11-07-06 11:36 AM |
| House curve...boost filter...what's the difference? | tdamocles | BFD Forum | 1 | 09-30-06 01:27 PM |
| House curve: What it is, why you need it, how to do it! | Wayne A. Pflughaupt | REW Forum | 3 | 06-26-06 04:47 PM |
