Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Which sub location is best (3 graphs)
Discuss Which sub location is best (3 graphs) in the Subwoofer Equalization | Calibration forum; Which sub location is best (3 graphs) There are only three corners in my room that I can use. Here are the graphs (sub only, mains not ...
Old 05-13-06, 05:53 PM   #1 (Link)
Alias: sid
User: #388
union1411 is offline
There are only three corners in my room that I can use. Here are the graphs (sub only, mains not on). Which will be easiest to tame with BFD and acoustic panels?
Front left:
Front right:
Rear left:
Old 05-13-06, 07:55 PM   #2 (Link)
Loc: Lower Alabama
Re: Which sub location is best (3 graphs)
I'd say the second one would be the best to work with. But lets raise the axix on that second graph to show from 45db to 105db and 15hz to 200hz... plus go ahead and save the graph at 800 pixels wide... then upload it again... it will give us a better comparison picture.
See this thread for more details on the graph posting.
Old 05-14-06, 05:24 PM   #3 (Link)
Alias: sid
User: #388
Ok, so I remeasured but only front right of room (it was the best of the locations it seems - and moving this sub is a pain )
I bought the Auralex GRAMMA today too - so this measurement is with the sub resting on it.
I saved pic at 800 pixels (but seems small on here - maybe it's a Photobucket thing)
Old 05-14-06, 05:31 PM   #4 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
So, the only difference between your previous front-right position measurements and this one is the addition of the subdude? I'd say the subdude didn't have any effect on SPL. Did you happen to perform a decay measurement before and after?
Old 05-14-06, 05:36 PM   #5 (Link)
Alias: sid
User: #388
Yeah the subdude/GRAMMA seems to have done nothing. I didn't do the decay measurements, because I am very very new to this (I barely know what I'm doing).
But I'll tinker some more. This stuff is addicting.
Old 05-14-06, 05:44 PM   #6 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
I'm interested in the decay specifically, but you should be able to easily test if the subdude isolated your sub from the house. Play something loud and stand next to the sub. The floor shouldn't shake as much. This was an obvious effect I got from my DIY subwoofer isolators.
A bit off-topic, but doesn't anyone else find the current forum layout annoyingly wide? I only fit about half the page width in my current browser window, and 800px for a graph is also too wide because you need about 100px or more for the username part on the left of a posting. Anyway, my gripe probably belongs in a different section.
Old 05-14-06, 05:44 PM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
So small I can't see it.
Repost your graph on this sites server so we can all see it....
Old 05-14-06, 05:51 PM   #8 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
800px is like 8 physical inches on my screen. But it is too small for you to see clearly?
Old 05-14-06, 05:52 PM   #9 (Link)
Alias: sid
User: #388
I attached it - hope that works better.
Old 05-14-06, 05:56 PM   #10 (Link)
Loc: Lower Alabama
It's a 734px width... but I can see it okay. It's about 4.5 to 5 inches wide on my screen in FF.
Can you upload your .mdat file (original measurement- if not the corrected one will be fine) as an attachment here... and .req file if you saved one.
Old 05-14-06, 06:07 PM   #11 (Link)
Alias: sid
User: #388
Here is mdat file (I had to remeasure because I haven't been saving mdats - like I said I'm new). This is with auralex. I'll do another without (my aching back).
Old 05-14-06, 06:11 PM   #12 (Link)
Alias: sid
User: #388
mdat without auralex (attached)
Old 05-14-06, 06:25 PM   #13 (Link)
Alias: brucek
User: #6
brucek is offline
Yep, that's great. It was exactly 3" wide on my screen before. The higher the res screen, the smaller the size....
That's a very good response. If that's without an equalizer, then you don't really need one.
Old 05-14-06, 06:33 PM   #14 (Link)
Alias: sid
User: #388
That's a ver good response. If that's without an equalizer, then you don't really need one.
Yeah it looked like a good response (compared to others' graphs). No EQ/BFD or bass traps. The BFD and GIK 244 traps, would run me a few hundred bucks. If you think the response is good as is, then maybe I can put that money towards the Paradigm Studios I've been wanting to upgrade to instead.
Old 05-14-06, 06:48 PM   #15 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, looks like your sub and room are working together nicely. I would not equalize that signal. Some might get nit-picky about some small bumps, but it's not worth digitizing a signal and having to be concerned about overdriving a BFD. Spend your money elsewhere.
Old 05-14-06, 07:20 PM   #16 (Link)
Alias: sid
User: #388
Also, after looking at the waterfall graphs (and reading the thread on how to interpret waterfalls), I've decided to return the GRAMMA. I see and hear little, if any, difference with it. It didn't even help with stuff like reducing rattling of doors, etc.
Old 05-14-06, 09:05 PM   #17 (Link)
Alias: sid
User: #388
Ummm . . . I realized I never applied radio shack spl meter correction values. So next post has the two new graphs with mic .cal loaded.
Old 05-14-06, 09:42 PM   #18 (Link)
Alias: sid
User: #388
So I ran new two tests with the mic .cal loaded. One test with sub in front right location and one with it in front left. I think I broke my back
Front right is 1st graph and front left location is 2nd graph.
Old 05-14-06, 10:07 PM   #19 (Link)
Loc: Lower Alabama
So this one has no corrections...
Old 05-14-06, 10:08 PM   #20 (Link)
Alias: brucek
User: #6
brucek is offline
I like the front right graph (#1).
You should now do one with the mains turned on to see what effect thay have around the crossover region. You might get lucky and the interaction will pull down the hump at 80Hz. Some sub phase adjustment might also work.
Old 05-14-06, 10:10 PM   #21 (Link)
Alias: sid
User: #388
