REW Forum
Moving REW EQ filter numbers into the BFD
Discuss Moving REW EQ filter numbers into the BFD in the Equalization | Calibration forum; Moving REW EQ filter numbers into the BFD I was reading a document that talked about setting frequency, fine, gain, and bandwidth in the BFD and how to ...
Views: 675 - Replies: 3
Old 01-25-07, 02:26 PM   #1
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
I was reading a document that talked about setting frequency, fine, gain, and bandwidth in the BFD and how to do this manually (MIDI is not working yet until I get my v1.4 chip). The entering/storing part is easy enough to follow.
But what I want to make sure I understanding is how to translate the values from REW filter results into the freq/fine/gain/bandw settings in the BFD.
Although I did not see any information on this, I think I figured it out by looking at things but just want to make sure.
OK, let's take the first EQ filter shown in the second screen shot of this post: http://www.hometheatershack.com/foru...31-post12.html
The first line for the filters shows this:
AUTO: PA 25.98, then in green are 25 +3, then gain of -7 and BW of 8, and then a Hz of 4.9.
Am I correct then to assume that when I set my filter in the BDF, I select 25 as the frequency, +3 as the fine, -7 gain and 8 bandwidth? Do I have this correct?
What is the Hz number for (in this case 4.9)? Do I need to do anything with this in BFD? Thanks!
Old 01-25-07, 03:06 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Moving REW EQ filter numbers into the BFD
Yes.............
No...........
Old 01-25-07, 04:02 PM   #3
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
lovingdvd wrote: View Post
I believe that this shows the frequency range of the current BW setting. It's based on how many 60ths of an octave, I believe. So a bandwidth of 5 would cover more frequencies at 80Hz than it would at 25Hz, because the octave is bigger at 80Hz.
Old 01-25-07, 04:48 PM   #4
Alias: lovingdvd
User: #5942
Since: Jan 2007
cyberbri wrote: View Post
Oh, very cool! Thanks for letting me know that is very useful.
