| REW Forum First real measurement subs, subs+main, subs+main largeDiscuss First real measurement subs, subs+main, subs+main large in the Subwoofer Equalization | Calibration forum; First real measurement subs, subs+main, subs+main large i took several measurements... one for each crossover point 80,100,120, with the subs alone and with the subs+main... then i ... |
| | #1 (Link) | |||
| First real measurement subs, subs+main, subs+main large i took several measurements... one for each crossover point 80,100,120, with the subs alone and with the subs+main... then i also did it with the subs+main and the l/r speakers set to large... so i was just wondering what u think of and make of my results... here are the first results of the sub by itself 80 then 100 then 120... | |||
| | #4 (Link) | |||
| Re: First real measurement subs, subs+main, subs+main large I'd probably leave the crossover at 80Hz. There isn't too much difference in the response with the three crossovers and 80Hz will be the least localizable. Your response is quite good. You could use some equalization for the peak centered around 55Hz. It would help to reduce it. Do you have a BFD? brucek | |||
| | #5 (Link) | |||
| Re: First real measurement subs, subs+main, subs+main large i haven't bought one yet... i wanted to measure first to see what i had before i decided to buy one... what kind of noticable difference does equalizing ur sub make??? also when i measure the sub and main(small) together why is there that huge drop down at 80hz??? should i keep my speakers set to small? aslo if i were to get the dsp1124 is there any good place to get one now that they are not produced anymore??? Last edited by frockc; 01-25-07 at 06:33 PM. | |||
| | #6 (Link) | ||||||
| Re: First real measurement subs, subs+main, subs+main large Quote:
brucek | ||||||
| | #7 (Link) | |||
| Re: First real measurement subs, subs+main, subs+main large thanks for all the help... i have a nht 12 sub which has a boundary eq and a phase 0/180 switch... when i get a eq and do measurments again i will try messing with those switches... | |||
| | #9 (Link) | |||
| Re: First real measurement subs, subs+main, subs+main large It is located in the corner... should i move it somewhere else i read that with one sub that is normally the best spot for it.? also if i were to add a second sub what would be the benefit to that other then better sub response for more seating positions..?? the room my setup in is a living room in my townhome which is open to the dinning room and kitchen and then stairs going up and down... so there is nothing closing off the living room other then a few half walls and stuff like that... i have sonance silverscreen 50s for L/C/R and nht 12 sub and then sonance 623tr for surrounds and a 623sstr for sbl/sbr... and then a marantz 8500 reciever... i decided to order a FBQ2496 so i'll get that next week and try equalizing the sub and changing the phase... thanks again for the help... Last edited by frockc; 01-25-07 at 10:28 PM. | |||
| | #10 (Link) | ||||
I knew nothing about bass equalization or even the need for it, until I got my sub and noticed it sounded way overbearing and muddy in deep bass scenes. Turns out that I had a nasty +15dB or so peak in the 40hz range and I'm using REW and BFD now specifically to tame this. | ||||
| | #11 (Link) | |||
| Re: First real measurement subs, subs+main, subs+main large The critical band is between 100 Hz and 5 Khz. Below 100 Hz is not very important and even high Q room resonances tend not to be audible. The measurements above 100 Hz should have high Q resonances damped out or notched out. The best way to handle room LF's is to use more than one sub, experiment with placement and phase settings. If you can put 3 subs in its unlikely you can experiment with placement much but you can exoeriment with phase settings. If you can take 8 shots then do this. (1) sub1 = 0 deg sub 2 = 0 deg sub 3 = 0 deg (2) sub1 = 0 deg sub 2 = 0 deg sub 3 = 180 deg (3) sub1 = 0 deg sub 2 = 180 deg sub 3 = 0 deg (4) sub1 = 0 deg sub 2 = 180 deg sub 3 = 180 deg (5) sub1 = 180 deg sub 2 = 0 deg sub 3 = 0 deg (6) sub1 = 180 deg sub 2 = 0 deg sub 3 = 180 deg (7) sub1 = 180 deg sub 2 = 180 deg sub 3 = 0 deg 180 deg = reversing connections. See which one gives you the best response. | |||
| | #14 (Link) | ||||
This means that primary reflections (second order) from the walls, ceiling and floor arrive at the listening position anywhere in the room with a phase shift of quite a bit less than a cycle. For example a 40Hz signal has a wavelength of ~28 feet. The limit here of about 100Hz with a wavelength of ~11 feet is reasonable for equalization..... It's important in home theater to remove the peaks caused at model frequencies to avoid low bass boominess. Multiple subs is a lofty goal that has benefits, but difficult to put into practice for most people (cost, WAF, technical ability, etc). The modal response at the listening position is easily and effectively controlled by second order filters (same Q, inverse gain) designed by REW software and implemented by a BFD parametric equalizer. brucek | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| two subs | bobgenie | BFD Forum | 15 | 10-22-07 03:07 PM |
| Will it power my subs | Lilmario215 | Chat Box | 3 | 11-02-06 10:40 PM |
| 4 subs for sale | vitod | Classifieds - Speakers and Subwoofers | 1 | 09-02-06 06:38 AM |
| Best Way to EQ 2 Subs? | Tukkis | Home Audio Subwoofers | 13 | 07-25-06 10:51 PM |
| One or Two Subs | Tommy | Home Audio Subwoofers | 42 | 06-01-06 11:06 AM |
