Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss Wishlist for next REW upgrade... in the Equalization | Calibration forum; Wishlist for next REW upgrade... We may as well go ahead and start a wishlist thread for the next REW upgrade. Post your suggestions in ...
Views: 2020 - Replies: 56
Old 01-26-07, 01:23 AM   #1
Owner
Loc: L.A. (Lower Bama)
Post your suggestions in this thread please! Thanks!
Old 01-26-07, 01:58 AM   #2
Alias: daxie
User: #4496
Since: Nov 2006
  daxie is offline
Re: Wishlist for next REW upgrade...
My request for total newbies:
* Step-by-step wizard interface...just connecting cables, clicking next, you know.
1) Setup soundcard
2) Calibrate soundcard
3) Setup SPL-meter
4) Calibrate SPL-meter
5) Other settings
6) Make first measurement
something like that.
Old 01-26-07, 01:11 PM   #3
Alias: Chrisbee
User: #33
  Chrisbee is offline
I have a couple. Not critical but desirable I think and certainly not meant as criticisms.
Keeping the target cut-off and meter cal curves visible after "all measured" button is pressed. It would aid comparisons between the curves rather than judging by eye.
More trial curves saved beyond the present 9. There seems to be lots of room in the left margin for at least twice as many. REW is so quick to use that many trials are easily possible in half an hour of trying BFD filters. I found myself repeatedly deleting valid trials and quickly lost sight of my first filter trials. So I was unable to monitor actual progress rather than follow hunches.
That said, these curves could have been saved as Jpegs or .mdat files if I really wanted them.
I consider 4.0 a considerable advance on 3.29. Thankyou John and friends.
Old 01-26-07, 01:28 PM   #4
niget2002
Inactive
Alias:
User: #
Posts: n/a
The only thing I can't seem to find is the following:
The ability to combine a calculated sub response with a measured speaker response to help with estimating their combined response. This may help when working with filters to make sure the crossover point isn't affected.
I like the idea of a wizard for initial setup too. Maybe help make it idiot proof by adding a simple setup diagram. (Soundcard-->receiver mic-->line-in)
The only other thing I can think of is if there was a way to "simulate" the filters by altering a signal going out to a receiver.
Old 01-26-07, 01:51 PM   #5
Alias: brucek
User: #6
  brucek is offline
Interesting.............
Old 01-26-07, 02:56 PM   #6
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
niget2002 wrote: View Post
That's relatively straightforward for the test signal, which then allows measuring the effects of filters without having to download them to a BFD (or even have a BFD). It will be part of the process of optimising the filter settings through multiple passes of measuring, applying filters, re-measuring etc. Needs some thought on how the UI for that works though. One of the (many) things on the dev list. Stay tuned
Old 01-26-07, 03:06 PM   #7
Alias: brucek
User: #6
  brucek is offline
Yeah, I thought that a rather smart suggestion by niget2002. It was right in line with the standard troubles lovingdvd was having with the remeasuring conundrum. It would be a great feature to have since you wouldn't need to enter your filters every time. You could just keep sweeping with a filtered signal until you liked the result. Then you would know that once you put in the filters to the BFD, it would be correct the first time......
Old 01-26-07, 03:14 PM   #8
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
brucek wrote: View Post
Yes, exactly. In fact I posted about this earlier today here: http://www.hometheatershack.com/forums/bfd-rew-forum/3247-how-do-i-measure-then-remeasure.html
So am I correct to assume that the way things work now you get one crack at it and once you measure you can't remeasure based on the last results, but rather you have to keep going back to the original mdat with the filters?
Man, this new simulated results feature would provide a HUGE leap forward in terms of ease of use and speed up the process greatly.
Right now its very tedious and time consuming to keep entering everything into the BFD manually. Will be better once my 1.4 chip comes so I can use MIDI, but the simulation will be fantastic. Funny thing is what I consider tedious must be light years better than how things were before REW and all this had to be manually calculated!!
Old 01-26-07, 03:17 PM   #9
Alias: lovingdvd
User: #5942
Since: Jan 2007
One feature I'd like to see is to have an option to have REW recommend or at least work with positive gains to fill gaps, at least smaller ones. I know adding gain is generally considered a no-no, but in some cases it makes sense.
brucek - I know you probably thought I was crazy the other day when I said that REW kept deleting my AUTO filters when I added them and told it to optimize... I figured out it was because these filters were for +dB (gains).
So my feature request is to have REW work with +dB gain filters that I add in as AUTO and take them into consideration when optimizing (even if it doesn't recommend any itself automatically). Thanks.
Old 01-26-07, 04:31 PM   #10
Alias: brucek
User: #6
  brucek is offline
Not really.... reduces dynamic range and signal to noise ratio. You want gain, turn up the sub....
Bookmark and Share
Dish Network
