REW Forum
REW will not calibrate the soundcard
Discuss REW will not calibrate the soundcard in the Equalization | Calibration forum; REW will not calibrate the soundcard Hi! Two days ago i downloaded the latest version of REW, and everything worked fine. Yesterday REW refused to calibrate ...
Views: 622 - Replies: 7
Old 01-26-07, 04:17 AM   #1
Alias: Ivaols
Loc: Norway
User: #5159
Since: Dec 2006
  Ivaols is offline
Hi!
Yesterday REW refused to calibrate the soundcard. I wired the output directly to the input, then set the output/input level to match, pushed "Next" button, and nothing happened. This worked fine the day before...
Here is what i tried:
Delete and download REW again.
Checked if the connections inside the PC is ok
Uploaded old cal.file of the soundcard, but when i push the measurement button nothing happens.
Shout and cry
I`ve waited 1 month for the Behringer, and when i finally get it REW wont measure.
Appreciate any kind of help!
Ivan
Sorry about my english
Old 01-26-07, 04:30 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: REW will not calibrate the soundcard
Hi Ivan,
Please look in your home directory (the location is shown in the About... box) and look in the roomeqwizardxx.log.txt log files to see if any error messages have been logged. Also post a screen shot of the soundcard settings. To have the effect of a clean installation, removing all the old settings, use the "Delete settings and shut down" option in the Settings menu and start REW again.
Old 01-26-07, 05:40 AM   #3
Alias: Ivaols
Loc: Norway
User: #5159
Since: Dec 2006
  Ivaols is offline
Thank you for quick reply! Will look into it as soon i`m home.
Old 01-26-07, 11:37 AM   #4
Alias: Ivaols
Loc: Norway
User: #5159
Since: Dec 2006
  Ivaols is offline
You are a genious!!! Its working
Thanks again!
Ivan
Old 01-26-07, 11:40 AM   #5
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Good to hear that Ivan. Did you find any info in the log files? Would be good to know what caused the problem so it can be avoided in future.
Old 01-26-07, 11:59 AM   #6
Alias: Ivaols
Loc: Norway
User: #5159
Since: Dec 2006
  Ivaols is offline
Hm, im sorry. Looked into the log files, but there where four of them, they where long and i could not quite figure them out.
Old 01-26-07, 12:47 PM   #7
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Could you email them to me Ivan? Would be useful to have them. john_mulcahy@hotmail.com
Old 01-26-07, 02:19 PM   #8
Alias: Ivaols
Loc: Norway
User: #5159
Since: Dec 2006
  Ivaols is offline
Ah, sorry again. They are already deleted. In the happy rush of getting things together i got rid of old problems.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
