REW Forum
How do I measure, and then remeasure?
Discuss How do I measure, and then remeasure? in the Equalization | Calibration forum; How do I measure, and then remeasure? Here's a scenario. I take a measurement, tell REW to Find Peaks and optimize them. Then I add a few ...
Views: 1075 - Replies: 27
Old 01-26-07, 10:36 AM   #1
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
Here's a scenario. I take a measurement, tell REW to Find Peaks and optimize them. Then I add a few filters to tighten things up a bit. So far so good.
Now at this point I want to run a measurement and see how the actual results are compared to REW's estimated results.
So I copy all the filters into my BFD. At this point I click on the Measurement button again, and now I get a new graph showing the results from my filters.
Now here is where I am getting lost... At this point assume I need to make some further tweaks. But this new Measurement does not have any knowledge about the filters from the last Measurement. I can add a few new filters but they are independant of what I'd done previously.
So at this point it cannot optimize the filters any longer (since it has no knowledge of the first set of filters). I repeat this process until I have things correct, remeasruing as necessary. But now I have say 5 different Measurements each with their own set of filters, together which makes the complete set of filters.
I guess what I am looking for is a way to Remeasure but within the same graph. In other words, instead of Measure creating results in a new graph, I'd like it to retain the previous filters and "Re-measure" within the same mdat. Is this possible? Seems like there should be a Remeasure button. What am I missing?
Thanks.
Old 01-26-07, 04:27 PM   #2
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Re: How do I measure, and then remeasure?
When I do it, I switch between the Left, Right and Sub tabs on the bottom right. So I'll maybe do a no-BFD reading on the sub tab and try out filters. Then switch to Left or Right and take a reading with the filters and compare it to the Sub tab's original measurements and predicted results for the filters.
I think there's a way to save data and recall it, but I haven't done any of that yet.
Old 01-26-07, 05:07 PM   #3
Alias: lovingdvd
User: #5942
Since: Jan 2007
cyberbri wrote: View Post
Thanks I didn't know those tabs were there. I'll have a look. However does this give you multiple tries within the same "document" or is it just an easier way to flip between mdats?
Yes I see the option to export the filter data, but there is no way to Import it that I can find into another mdat so it needs to be retyped every time I take a new measure....
Old 01-26-07, 05:19 PM   #4
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
It just lets you view different graphs while keeping the original with the filter suggestions in place. I found that the filter predictions weren't very good in my case, so it let me keep the original and the filter suggestions, plus take 2 more separate graphs and compare them all.
Old 01-26-07, 05:36 PM   #5
Alias: brucek
User: #6
  brucek is offline
They're not - that was in old versions. They have been replaced completely in Version 4 with a better method....
Load and Save filters....... easy. Export is only to get a text format.
Old 01-26-07, 06:23 PM   #6
Alias: Wade
adogand6kids's Avatar
Loc: Minot, North Dakota
User: #1793
  adogand6kids is offline
So I'm looking around the new REW v4 and I can't figure out how to measure and then re-measure if there are not separate channel tabs? Did I misunderstand what BruceK was saying about there being a better way? Am I missing a help file that explains how to set a filter then check the effect of that filter... what lovingdvd posted initially?
Old 01-26-07, 07:13 PM   #7
Alias: brucek
User: #6
  brucek is offline
The best thing would be to read the REW HELP files. They're quite well written.
Each time you hit measure it creates a new set of measurements and keeps the last set too. You can keep 9 sets at once.
It's all in the help file..
Old 01-26-07, 07:34 PM   #8
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
I'll have to see what version I'm using, then. I only downloaded it just a few weeks ago...
Old 01-26-07, 07:45 PM   #9
Alias: brucek
User: #6
  brucek is offline
REW V4 just became available on Monday... You're in for a surprise...... it's quite nice.
Old 01-26-07, 07:50 PM   #10
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Let me ask a question of my own, since my own thread died without any answers.
Besides measuring frequency response, what else can REW be used for? I know there are the waterfall charts, etc., but how can they be used to analyze and evaluate room acoustics, ringing, etc.? Ie., if I want to see what adding bass traps has done for my room/response besides just changes in frequency response, what can I do and how do I do it?
Is there an advanced REW guide?
Old 01-26-07, 08:46 PM   #11
Alias: lovingdvd
User: #5942
Since: Jan 2007
brucek wrote: View Post
I have read the help files from start to finish and they are excellent. However in practice there are many questions that come up that are not addressed.
You mentioned that each time you hit measure it crease a new set of measurements and keeps the last set too. But in the new Measurement there are no filters? So are you supposed to save the filters and then reload them in the next measurement? Why not just have them carry forward?
Better yet, it would be great if there was a REmeasure command where it just overwrote your last measurement but kept all your filters and settings and so forth.
Old 01-26-07, 08:48 PM   #12
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
lovingdvd wrote: View Post
There isn't that option? I haven't upgardet to V4, but in the previous version I could take a measurement, apply filters in REW, and if I took another measurement it would overwrite the previous one but keep the filters and apply them to the new graph.
Old 01-26-07, 08:56 PM   #13
Alias: lovingdvd
User: #5942
Since: Jan 2007
I'm very new to REW (just started working with it a few days ago) so I'm hesitant to say definitively 'No' - however I can't find a way to do what you say and that's the whole purpose of this thread - I want to do just that but don't see how.
Old 01-26-07, 08:59 PM   #14
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
That'll suck if it's been taken out...
I'll have to install V4 in a different location, just in case.
I can possibly post the previous version's install files.
I should still have them on my computer.
Old 01-26-07, 09:46 PM   #15
Alias: brucek
User: #6
  brucek is offline
Seriously, how long does it take you to click two selections?
Click - Save Filters
Click - Load Filters.
It took me longer to type that, than it would for you to click it...... I suppose it could have been incorporated into a single button, but it wasn't.
It's two clicks.............
Old 01-26-07, 10:11 PM   #16
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Well, I've only played with 4.0 a couple times, but I think that's correct. There are a total of nine measurements -- they're along the left side of the GUI. So, if you measured once, your measurements are in window #1; measure again, in window #2, etc. If, on your second measurement, in window #2, you determine some filters and apply them to the BFD, that information is saved in window #2 (at least temporarily -- you have the option to store it more permanently by selecting the File->SaveFilters option (or similar)).
OK. So you did measurement #2, downloaded them to the BFD and you're ready to do measurement #3. So you do that, and you get the result of whatever filters you had applied previously. The filters from #2 are not there. And you're right -- they don't really "carry forward".
However! They are still preserved in #2, and it's easy to go back there to continue to tweak those filters. Now, you can also go to the "All measured" tab and select which measurements to view. That way you can see #2 and #3 at the same time.
I agree that there should be an option.
-- Otto
Old 01-27-07, 12:24 AM   #17
Alias: lovingdvd
User: #5942
Since: Jan 2007
Otto wrote: View Post
Yes, that seems logical. After all the second measurement is based on filters from the first, and so forth. Having the filters automatically "stick" between measurements would really help streamline the experimentation.
Old 01-27-07, 01:33 AM   #18
Alias: Dent
User: #416
  Dent is offline
But if you save the filters from the first measurement and then load the filters into the second measurement (or if the first measurement filters were automatically carried forward) then you would be then applying these first set of filters on to the new measurement. Since the new measurement already has the first set of filters applied (because you entered them into the BFD) that would be the same as doubling up all of your filters which would throw everything out of whack.
Old 01-27-07, 01:37 AM   #19
Alias: lovingdvd
User: #5942
Since: Jan 2007
Dent wrote: View Post
Yes, of course. Doh!
Old 01-27-07, 08:05 AM   #20
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Well, not quite. If I measure with filters assigned from measurement #1, I now have measurement #2. If filters carried forward from #1 to #2, they are just there for me to download again, or not. If I download the same filters, I will get the same result as I did in #2, because they are the same filters.
Now, if the filters carry forward, and you tweak them a bit, you will get a different result than you did in #2. Still, you should only get a delta in the areas you tweaked, and there won't be a doubling up because you only made small changes. This is how I do it, and I've tweaked quite a bit when trying to boost below 20 Hz without getting unwanted peaks above 20 Hz.
I think what we may really want is for REW to "know" which filters are in the BFD and then calculate new filters "on top of" the current filters. REW would then be doing the tweaking for you. The problem is that REW doesn't really have a way of knowing what filters you are using. In these cases, we could assume that it's the filters from the previous measurement, but that wouldn't always be true. Suppose I have already set up filters in banks 1 and 2 of the BFD. Now I just want to see the difference between the two and I do a couple measurements using REW. As far as I know, without loading saved filters or somehow reading them from the BFD, REW has no way to know what filters are in banks 1 and 2. Even if REW could determine the filters being used, I think I'm over-complicating things at this point.
All in all, I do think it's easy enough to just bounce back to the previous measurement in REW 4. I think it will lose it after nine measurements, but you can save it and then it's there forever. And actually, there may already be some option to not advance the measurement. I haven't played around with version 4 enough yet. Overall, it's an improvement over the previous releases. And just to be clear to JohnM and everyone else -- I don't think anyone's complaining about the tool. It's tops! I don't know what I'd do without out it. Have shabby bass, I guess. Or shell out $$$ for an SMS-1.
-- Otto
Old 01-27-07, 09:03 AM   #21
Alias: brucek
User: #6
  brucek is offline
Yep...... that's correct.
That's why you don't want the previous measurements filters to automatically move to the next measurement. If you do, simply click Load Filters that you saved. This would be the case where you perhaps disable the BFD filters and take a new raw measurement, but want the filters from the last. Simply Load Filters............
Old 01-27-07, 09:34 AM   #22
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Not sure. I'm thinking that I just want to be able to repeatedly measure, tweak filter values manually, send them to the BFD and remeasure. After the remeasure, I may want to slightly tweak and download filters to the BFD. In that case, there is no doubling.
-- Otto
Old 01-27-07, 11:00 AM   #23
Alias: lovingdvd
User: #5942
Since: Jan 2007
Yes, exactly. I think that would be much easier.
Old 10-08-07, 07:49 AM   #24
New Member
Alias: Ian
Loc: Nottingham England
User: #9462
Since: Jun 2007
  ianfromnotts is offline
Any progress on this suggestion yet? I was looking for the same solution.
Old 10-08-07, 07:45 PM   #25
Alias: toecheese
Loc: Raleigh,NC
User: #356
  toecheese is offline
As the others have posted, for my initial setup, this 'measure', save filters, measure again, load filters, chose overlay tab, select the last-two measurements, don't obscure filters, rinse-repeat is not ideal.
I was hoping I was doing something wrong, but it doesn't appear that way. In the old version I was pretty sure I didn't have to keep loading from disk.
Since that's the way it is, then I'll deal with it, it is certainly more than two clicks though because it wants file names and descriptions each time I save.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
