Problem writing House Curve files - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Problem writing House Curve files in the Subwoofer Equalization | Calibration forum; Problem writing House Curve files Hello, I am having a little trouble writing a few house curve files. I need to create three curve because ...
Old 01-29-07, 02:16 PM   #1 (Link)
Bronze Supporter
Alias: Julien
Loc: Western NC
User: #4401
Since: Nov 2006
Julien43 is offline
Hello,
I am having a little trouble writing a few house curve files. I need to create three curve because I am going to equalize my mains speakers
and their "Sub Inputs" The Mains in will roll off below 50htz. The "Sub In" will roll off above 50htz
I would like the combined curve to start at 65htz and rise 6db to 30htz (as recommended by Bruce)
Can anyone help me with the text files. I will need one for the mains, one for the "Sub In", and still another with the curves combined
Every time I try to implement the files I have written it's a mess
Can some one point me in the right direction
Thanks
Julien
Old 01-29-07, 02:37 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Problem writing House Curve files
A house curve is applied to the target that is selected at the time.
You haven't really supplied enough information about the curves or the targets or the rolloff/dB.
I am a bit confused.
Maybe start by explaining the subwoofer house curve. Once that one is done, we can look at the next one..
Old 01-29-07, 03:21 PM   #3 (Link)
Bronze Supporter
Alias: Julien
Loc: Western NC
User: #4401
Since: Nov 2006
Julien43 is offline
Well Bruce, The "Sub In" starts with a 50 Htz signal The problem is that i want the boost to start at 65htz with an over all boost of 6db to 30 htz
I don't have a good handle on how to write the text files. They don't come out the way I want them to
I am not sure where that puts the boost at 50 htz
As far as the roll off goes. I need a starting point that is least likely to cause a boost or dip at the 50htz region
I know I'll have to adjust these when I apply them together.
I know what I want to see for the target but I don't know how to write the files to make it all come together
Thanks Bruce!
I want to make sure, when I combine the two curves, I have a smooth response
Old 01-29-07, 05:13 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Again, I really don't get what you mean.
Usually, you specify a standard crossover that REW can draw such as a 50Hz @ 24dB/octave subwoofer crossover.
Then you add a modification to it in the form of a file.txt that you load with the Settings feature in REW.
I'm sure I'm wrong, but as an inital attempt at interpretting what you're talking about, I show a plot of a
50Hz @ 24dB/octave subwoofer crossover and then another plot laid on top (used photoshop) where I added a housecurve to the standard 50Hz - 24dB/octave subwoofer crossover in a file with two entries. The file entries are shown.
Again, you have to tell me what you want before I can do the job..
Old 01-29-07, 08:01 PM   #5 (Link)
Bronze Supporter
Alias: Julien
Loc: Western NC
User: #4401
Since: Nov 2006
Julien43 is offline
Thanks for your patience Bruce
I need to take three measurements
1)Everything below 50htz
2)Everything above 50htz and below 200htz. This will be a fullrange response. (no crossover rolloff)
3)A combination of the two above ranges
The first two measurements are for separate voice coils of the same driver. The third is to see how well they integrate.
I have written the target curve for the combined measurement.
15 -4.0
22 6.0
30 6.0
50 3.0
65 0.0
I'm not getting the same thing when I try to create House Curves for the first two measurements. They just don't match the combination
Old 01-29-07, 08:52 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Well, I don't know if I have this right, but it's worth a try.
I think first it has to be accepted that if you use a standard 50Hz crossover high pass and standard 50Hz crossover low pass target from REW, that the resultant combined outout will be flat as seen as the red line in the plot below.
So if we simply lift the low pass target with the simple house curve as shown, I would say the resultant would be as shown in the upper dotted line. It looks close enough to give it a try anyway. It gives you something to work with anyway. I see no reason to reduce the curve at 15Hz. Let the bottom drop as it may.
Similar Threads
Creating my first house curve lovingdvd REW Forum 7 01-26-07 06:24 PM
Sub level post house curve jaz123 REW Forum 3 12-29-06 10:32 AM
House Curve Options Ayreonaut REW Forum 21 11-21-06 08:13 AM
Target response / House curve sonata31 REW Forum 6 11-07-06 11:36 AM
House curve: What it is, why you need it, how to do it! Wayne A. Pflughaupt REW Forum 3 06-26-06 04:47 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
