| REW Forum Alarms in REW?Discuss Alarms in REW? in the Subwoofer Equalization | Calibration forum; Alarms in REW? Today I ran some tests with REW to tweak the subwoofer distance stting in the AVR. When I first connected ... |
| | #1 (Link) | |||
| Alarms in REW? Today I ran some tests with REW to tweak the subwoofer distance stting in the AVR. When I first connected it all up I connected the mic to the wrong input channel on my soundcard. I ran the sweep and there was a high pitched beeping playing through the speakers during the sweep. When I fixed the connections it went away. What a cool feature. Harry. | |||
| | #2 (Link) | ||||
| Re: Alarms in REW? Quote:
There is no doubt and it was as clear as day the the amps auto distance setting produced the best response with mains and sub. Even though it was "wrong" compared to the physical and BFD 1ft adjustment rule. I've always suspected that the Amps delay/distance settings are more likely to be right than using a tape measure! Now I have proof. Well for the sub at least! | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name | ||||
| | #3 (Link) | ||||
| | #4 (Link) | ||||
| Re: Alarms in REW? Hmm...I dunno whats going on then something was sending an alarm through my system. Quote:
My physical measurement is 2.6m but I got the best integration setting it at 3.6m. | ||||
| | #5 (Link) | |||
| Re: Alarms in REW? Misaligning the distance setting changes the phase through the crossover region... If you have variable phase on your subwoofer, try rotating it 90 degrees and run the auto config thing again. If it's worse, try rotating 180 degrees from that position. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||
| | #6 (Link) | ||||
Yep, thats the idea, my sub amp doesn't have a phase control so the distance setting can be used to infinitely adjsut the phase. | ||||
