REW - Possible?? Measuring using Pink Noise from Source Player - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss REW - Possible?? Measuring using Pink Noise from Source Player in the Subwoofer Equalization | Calibration forum; REW - Possible?? Measuring using Pink Noise from Source Player Hi All Gurus, This is the FIRST Thread that i posted here. I have 3 questions here to ask about ...
Old 05-15-06, 04:53 AM   #1 (Link)
Alias: media2368
User: #12
media2368 is offline
Hi All Gurus,
I have 3 questions here to ask about REW:
1) I am using a External USB sound card with REW, SPL meter will connect to LINE-IN of the sound card. Can I not use the Sound care's LINE-OUT to AVR but just use my source (DVD Player) that has already connected to my AVR to play the Pink noise for Freq Resp measuring? Any trade-off or anything that I need to adjust in order to get REW to work properly?
2) If I use the sound card's LINE-OUT (let said LEFT line-out) connect to AVR's Left input, will it the FR measure correctly? The reason I asked it because to my understanding low freq found in ALL CHANNELs (not only LEFT) so will the FR being measure correctly by using this connectiong method?
3) In REW Tips found in this forum, under View and select 2 Impulse Response Controls. I DOES NOT ALLOW me to Change the Pre-ref Window Width (ms) to 125. Is it because I didn't take any measurement so it doesn't allow me to change the PRe-ref Window Width?
Hope you guys can assist me on the aboved questions.
Thank you in advance.
Media2368
Old 05-15-06, 07:23 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: REW - Possible?? Measuring using Pink Noise from Source Player
I don't see the upside in this idea. Simply use the LINE-OUT provided by REW and you'll get the advantage of all the features provided with pink noise, log sweep, linear sweep, sine wave and square wave. The program is calibrated to be used with both input and output. The soundcard calibration is an amalgamate of the inadequacies of the input and output.
You can use any available line input on your receiver - AUX / CD / DVD / TAPE etc....
You can't change the pre-ref window until you take a measurement.
Old 05-15-06, 08:03 AM   #3 (Link)
Alias: media2368
User: #12
Hi Brucek,
Thanks for your reply.
But is Single Line-Out (Sound Card) to Single Line-In (AVR) good enough for measuring?
Someone told me to us Y-Adapter from Single Line-Out (Sound Card) to L+R Line-IN (AVR)...which is correct?
And I have heard that measuring the signal from the Source (DVD Player or CD Player) will be much accurate...afterall the Source is THE ONE that play Movies/Music...
Sorry I am not trying to urgue....just too confuse ...hope you can help..Thank you so much.
Old 05-15-06, 08:59 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Both are correct in that the plugs on a soundcard are stereo, but we only want to use one channel for both input and output.
So you must plug in a stereo adapter that has an 1/8" stereo jack on one end and two RCA plugs on the other end. Now you only use one of the RCA plugs.
You'll need two of these adapters hanging out of the back of your soundcard.
Old 05-15-06, 09:26 AM   #5 (Link)
Alias: media2368
User: #12
I am using this external USB sound card.
So I can just use one RCA Plug (from sound card either L or R) to one RCA Plug (from AVR either L or R).
But if I am going to measure the Main speakers, then I will have to connect BOTH L + R from Sound card and AVR.
...OH..I think of a question..but might sound stupid..if I connect BOTH L + R from Sound card and AVR to measure Subwoofer freq respond, will it play louder than using just L to L from sound card and AVR? (Or REW will automatically adjust the sound level on it software side to make sure that it measure correctly? Will it affect the SPL level calibration for the subwoofer?)..
Sorry..my understanding is really bad...hope you have patience to reply my doubt... I really appreciate..Thanks.
Old 05-15-06, 09:35 AM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, didn't know you had an external. Yep, if it has separate left and right RCA input/output, simple use one.
No, still only use one, but when you plug this one into the receiver, use a Y-splitter to left and right in.
Old 05-15-06, 12:03 PM   #7 (Link)
Alias: media2368
User: #12
Hi Brucek,
Thank you so much for your time. And my doubt for all 3 questions have been clear.
Here I have another question for REW.
After measuring the Freq resp > Find Peak > Optimise PK Gain & Q, is there anyway to apply Filter on the Screen and do another step of Find Peak > Optimise PK Gain & Q > 'Apply Filter on Screen' until I am satisfy with curve before we apply the exact Filter data to the BFD?
Old 05-15-06, 01:14 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Absolutely, except you don't do another FIND PEAKS, etc.
The FIND PEAKS routine is a great suggestion for filters. Once you've done this step though, now is when you start to add more filters manually using the dynamic representation on the REW screen as you adjust them to see the predicted results.
You can also modify the suggested filters too if you like.
Usually, what you see in the end result on the REW screen after playing around with filters, will be the actual result after you enter the filters into the BFD and remeasure.
The only caveat there is that any filter with 'gain' may not result in exactly the predicted result. Sometimes its fine ane sometimes its not. If you throw gain at a dip and it responds - great. If not, remove the filter.
Old 05-16-06, 01:12 AM   #9 (Link)
Alias: media2368
User: #12
Thanks Brucek,
I will let you know if I have any further question. Cheers!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
