REW ForumDiscuss first manual attempt? in the Equalization | Calibration forum; first manual attempt? Hey, this is my first manual graph no bfd yet how does it look? awful I know........ |
Views: 866 - Replies: 23
| | #2 | ||||
| Re: first manual attempt? You could benefit from a BFD equalizer. I guess you already know that. If you want an accurate measurement that makes the whole process so much easier, try out REW. Not many things come free these days... this one does... brucek | ||||
| | #5 | |||||||
| Re: first manual attempt? Quote:
brucek | |||||||
| | #6 | ||||
| Re: first manual attempt? PhilB, Unless you have the patience of a saint and would get some sort of perverse pleasure from setting up a BFD manually, then I strongly recommend using a PC with the REW software, together with MIDI capabilities. If you have a desktop PC with a "gaming card" in which you could put a joystick, then the same port can be used for MIDI. Which is what I do. It saves ooodles of time and prevents premature alopecia! If not you can get a USB MIDI connection. Or if you have a laptop then you will need an external soundcard anyway, so go for one with midi capabilities. All IMHO!! Bob | Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant| Bob - "Malice" was my Quake 2 CTF name Last edited by Malice; 02-04-07 at 12:08 PM.. | ||||
| | #10 | |||||
SPL is an acronym for sound pressure level. If you're asking whether you could use REW to chart external readings already obtained by some other means, then the answer is yes, if they're in the correct format. I'll just print out the specific section in the REW HELP file I previously suggested reading..... I have edited out things that may not pertain to you. ----------------------------------------------------------- Importing Measurement Data Frequency Response Text Files File - Import Measurement command accepts text files in the following formats: Cubic spline interpolation is used between sample points Generic comma, TAB or space delimited files Data must be presented as freq, SPL pairs, one pair per line Samples can be at arbitrary frequency spacing, but each line must have a higher frequency than the one before and there must be at least 5 freq, spl data pairs Only lines which begin with a number are imported, others are ignored In comma-delimited files there must be at least one space after the comma Spaces before values are ignored To add a comment on a data line put a tab, comma or space after the spl value Comma-delimited File Format Here is an example of a valid format for comma-delimited data: SPL measurements acquired by Room EQ Wizard V3.08 Source: D:\RoomEQ_Wizard\test files\testfile.txt Format: Comma delimited data Dated: 05-Mar-2005 17:53:56 Channel: Left, Bass limited 80Hz 20.0, 65.01 21.0, 65.77 22.0, 67.50 23.0, 67.93 24.0, 68.22 25.0, 67.88 26.0, 67.92 27.0, 68.31, this line has a comment 28.0, 69.14 29.0, 69.16 30.0, 69.29 If comma is used as the decimal delimiter in your locale it is best for clarity to use TAB or space as the separator. Space-delimited File Format Here is some data in space-delimited format SPL measurements acquired by Room EQ Wizard V3.21 Source: D:\RoomEQ_Wizard\test files\testfilespace.txt Format: Space delimited data Dated: 27-May-2005 13:03:26 Channel: Left, Bass limited 80Hz 20.0 65.01 21.0 65.77 22.0 67.50 23.0 67.93 24.0 68.22 25.0 67.88 26.0 67.92 27.0 68.31 this line has a comment 28.0 69.14 29.0 69.16 multiple spaces are OK 30.0 69.29 -------------------------------------------------- brucek | |||||
