REW Forum
What to use for input
Discuss What to use for input in the Equalization | Calibration forum; What to use for input I am looking at downloading REW so I can play around with my home theator. I am wondering what exactly ...
Views: 647 - Replies: 4
Old 02-06-07, 04:05 PM   #1
Mopar_Mudder
Inactive
Alias:
User: #
Posts: n/a
I am looking at downloading REW so I can play around with my home theator. I am wondering what exactly you need to get the readings into the PC. Is just the standard sounds card in my 1 year old HP lap top good enough, it has a mic input. I also have a PC with an older Sound Blaster card.
And for the Mic I do have an anolog Radio Shack SPL meter but is it acurate enough? I also have a mic that came with my Yamaha V2400 receiver for its auto set-up, can this be used in any way.
Sorry for all the newbie questions.
Old 02-06-07, 04:32 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: What to use for input
No, for a laptop you need an external USB soundcard.
That will work fine..
With our downloadable calibration files, it is accurate enough for subwoofers..
No, we don't have a cal file for that. The RS meter is fine...
REW HELP FILES
Old 02-07-07, 03:49 PM   #3
Mopar_Mudder
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
What about for the standard speakers then, I asume you can use REW for this also, Is a real mic then needed?
Is they anywhere you can buy a calibrated mic with a correction file?
Old 02-07-07, 04:16 PM   #4
Alias: brucek
User: #6
  brucek is offline
Those that test full range, so they can check room treatment, usually have a better microphone. REW certainly works full range with a decent mic. A popular one is the Behringer ECM8000. It also requires a preamp to work. The ECM8000 mic is fairly consistent between units. Sonnie has his calibration file posted on the site and it would be quite close to use.
Old 02-07-07, 04:19 PM   #5
Alias: terry
Loc: bathurst nsw australia
User: #1819
  terry j is offline
I simply use the ECM 8000 file provided by Sonnie with obviously an ECM mic. In comparing the results with that with the results I get from using a calibrated ECM with the deqx, the results are certainly close enough for me.
