REW Forum
help!
Discuss help! in the Equalization | Calibration forum; help! i can't get this program to work on a mac or my pc.. i'm using a mbox and it REW ...
Views: 542 - Replies: 2
Old 02-06-07, 05:43 PM   #1
xmostynx
Inactive
Alias:
User: #
Posts: n/a
help!
i'm using a mbox and it REW doesn't see it on a pc. and on a mac nothing i loud enough...i can only use this program when using the internal speaker on my macintosh....anyone want to help this is totally bumming me out.
all this software does is quit out on a mac... os 10.4.8
Old 02-07-07, 08:39 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: help!
You'll have better luck using the PC than the Mac for the moment. If you can see your Mbox in the Windows sounds and audio devices properties REW should be able to see it, it's just a USB soundcard so there shouldn't be a problem. Note that if you plug the Mbox in after REW has started it can take up to a minute for Java to detect it, easier to plug it in before starting REW.
Old 02-07-07, 12:06 PM   #3
xmostynx
Inactive
Alias:
User: #
Posts: n/a
Re: help!
yea windows can see it only as a playback device not an input device...
so i can't plug in a microphone into the mbox and use it.
it seems like the mac version is only working when i use my internal mic on my imac-
for some reason it alwys quits out when i try it with a 57 hooked up to the mbox.
