REW Forum
Did I do this right? Waterfall Graphs
Discuss Did I do this right? Waterfall Graphs in the Equalization | Calibration forum; Did I do this right? Waterfall Graphs Did I do this right? And I sort of know what I'm looking at, but maybe someone could tell me ...
Views: 1020 - Replies: 3
Old 02-07-07, 01:13 AM   #1
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Did I do this right? And I sort of know what I'm looking at, but maybe someone could tell me what this all means...
I opened up the .mdat files from my last testing session.
I set the time range to 400ms, window to 200ms.
dB range is 100 to 58dB - is this correct?
Sub plus mains.
Any other info/parameters I should post?
Should the time range be 400ms, or something else?
This is the original measurement, with no bass traps, waterfall.
This is with my bass traps and after eq'ing:
My HT Gallery (Updated pics of my setup and room treatments)
My REW measurements with bass traps and BFD eq
Old 02-07-07, 08:28 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: did I do this right? waterfall graphs
You would get better frequency resolution by using a longer window, say 300ms window and a 500ms span. It looks as if you have a filter set at just over 50Hz whose bandwidth is too narrow, which is why you can see a reverberant tail at that frequency in the eq'd plot which is not present on the original measurement. The filter for the peak at around 75Hz also looks like it may not be ideally matched to the resonance, but it's pretty close. Try tweaking the filter settings and re-measuring to get a feel for the effect on the waterfall.
Old 02-07-07, 11:56 AM   #3
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Thanks, John.
I thought something strange was going on around 50Hz. I'll definitely do what you suggest.
And is the dB span good? Going down to 60dB or so? Or should I go lower, or even higher?
Old 02-07-07, 12:06 PM   #4
Alias: brucek
User: #6
  brucek is offline
When I look at mine, I keep the standard 45dB to 105db.........
