Is the film industry's X curve suitable for home theater? - Home Theater Forum and Systems -
post #1 of 3 Old 05-28-09, 08:33 PM Thread Starter
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Is the X curve suitable for home theater?
Part 2
An X Curve for the Center Channel?
House curve / X curve confusion
In Part Three of my article, House curve: What it is, why you need it, how to do it, we saw that the film industry uses a standardized room curve for both production (soundstages) and reproduction (movie theaters), known as the X curve. On the home theater front, it’s not uncommon to see enthusiasts confuse the X curve with a house curve. The following quotes are from a couple of discussion threads that originated right here at The Shack (emphasis added):
“Vote for your favorite Room Voicing Curve.
1. Academy Curve
2. X-Curve
3. No Curve at all!”
“I am interested in what you think is a house curve ‘appropriate to the room’. I may be wrong but I think for a home-sized listening room, the appropriate house curve is zero. The need for an X-curve EQ gradually diminishes with room size from 100% for an auditorium or theatre, to zero for typical lounge or listening rooms.”
“Let us say an orchestra (or solo piano) is playing in a world class venue, and the recording mic is placed in the best seat in the house, say centre stage, 20 rows back. No EQ or compression is applied to the recording. When we play this back in our homes, what is the ideal room curve? It is flat, not X curve. Flat EQ will reproduce the same bass-to-treble balance in the listening seat as in the seat where the mic was placed. Playing the above recording through an X-curved system will sound far too dead due to the attenuated treble.”
As you can see, these parties freely interchange the X curve with a house curve as if they are the same thing, and also assume the X curve is an option for a domestic system. Therefore, it bears noting again that the X curve is specific to the film industry. No other professional audio field that I am aware of uses the X curve, or any specified room curve for that matter.
Origins, applications, and practical limitations of the X curve
To show that the X curve is wholly inappropriate for a residential/consumer audio system, it’s beneficial to know something about its origins and purpose. As best as I can tell by wading through this Tomlinson Holman article and Dolby Lab’s History of the X Curve, it’s something the film industry came up with decades ago to address the deficiencies in both optical soundtracks and the speakers of the day. Ioan Allen of Dolby Labs and other movie industry professionals did some experimenting on a soundstage in England back in the early 1970s, comparing hi-fi KEF speakers located near-field with old-school, two-way Vitavox film monitors located far-field, equalizing the latter until they felt a timbre-match with the former had been achieved (which strikes me as a futile exercise going in, but that’s a discussion for another day).
After this exercise the film monitors' response was electroacoustically measured. All parties in attendance where surprised to find they exhibited not the KEF’s verified flat response, but a roll out of the high frequencies above 2 kHz. No one could readily explain the discrepancy, even though it seems there was no shortage of places to look. They could have started with the speakers themselves: The Vitavoxes were dead in the water above 8 kHz. Perhaps their prehistoric compression drivers sounded nasty with the highs suitably elevated, so the sound engineers instinctively kept them rolled back. Or perhaps the primitive equalizers the engineers used did the film monitors no favors. Who knows? What’s glaringly apparent is that the parties involved made no attempt to get to the bottom of it.
Regardless, the enhanced response measured for the Vitavox monitors was later adapted as the X curve. Subsequent testing and measurements in movie theaters of the day took reverberation into account and further validated the X curve’s high frequency roll off as suitable for maximizing speech intelligibility in movie soundtracks. A low-end roll off below 63 Hz was implemented to minimize distortion from overloading the full-range speakers commonly used at that time (before commercial subwoofers were commonplace).
An outdated standard?
“Speech intelligibility”: that should tell us right there that the X curve was never intended to maximize the capabilities of extended range, high fidelity sound systems. One could argue that since the highest fundamentals of the human voice – the sibilants – are about 7.5 kHz, there’s no need for a speech-optimized speaker to have extended range. But there are numerous musical instruments with harmonics that can reach an octave or more higher – violins, cymbals and other percussion instruments. Instruments like electronic synthesizers can generate fundamentals above 8 kHz, as can sound effects generated by Foley artists. Apparently it’s not enough that a movie’s music soundtrack will typically be mixed at a lower level than the dialogue. The concern seems to be that if not squelched, the music track’s extended high frequency content will swamp the upper registers of the dialogue, rendering it unintelligible.
Whatever the reason, over the decades as advancements in professional loudspeaker design have improved both low- and high-end extension, the film industry has rigidly adhered to the X curve, essentially keeping movie theater sound “dumbed down” to the level of the limited-range speakers used back in the ’60s and ’70s. Adding insult to injury, modern theaters are much more- and better-dampened than they were in the past, diminishing the effect of reverberation on both measured response and speech intelligibility; yet the X curve remains. Small wonder that modern movie theaters sound as dull and lifeless as they do.
It should take only a small leap in logic to determine that an X curve will not sound good in a home theater system. As explained in Part One of my house curve article, it has problems going in simply because it is a type of rigid-value slope that presumes to be the reference standard for any and every room, no matter what the size. Bottom line, the X curve was never intended for our tiny rooms and has no place in a domestic setting. The only possible exception I can see would be for the center channel speaker.
Thanks to brucek for his excellent Excel program, from which we created our X curve chart.
Is the film industry's X curve suitable for home theater?-x-curve-original-nearfield-vs.-farfield-testing-1972.jpg
post #2 of 3 Old 05-28-09, 08:38 PM Thread Starter
re: Is the film industry's X curve suitable for home theater?
Part 2
An X curve for the center channel?
An exception I can see for the “no X curve” rule, as well as the “minimize per-program tweaking” rule, would be for the center speaker, which is primary dedicated to reproducing dialogue. After years of constantly adjusting my treble control up and down to compensate for poorly equalized voices, I’ve come to the conclusion that perhaps some kind of dedicated curve is necessary for the center channel. Not to address relative distance from the display or reverberation in the room as the movie industry’s X curve does, but to compensate for program content that is poorly equalized.
Why can’t they get voices right?
After bass, voices seem to be the most abused thing in the world of audio reproduction, as far as proper equalization is concerned. It’s not uncommon to hear male voices that are unnaturally “boomy” because of excessive low-end boost, but most often the problem is the treble – more specifically, sibilants that are not properly balanced with the rest of the voice. Too often they are either exaggerated or muffled. Sometimes you can hear examples of both present in the same program, which is especially maddening. A common example is news shows that have remote, on-location interviews piped to the studio: One talking head will have well-balanced voice equalization, while the other has exaggerated, “crispy” sibilants. Not that TV shows and movies are exempt – I’ve seen it there as well.
It’s easy enough to determine if you’re hearing natural-sounding voices from your system. Just have someone stand in front of your display, while you’re sitting in the primary listening position, and repeat some phrase rich in sibilants, such as “Simple Simon savors luscious twinkies.” (You will probably want to come up with your own phrase.) Have them repeat it until you have a good “feel” for how the “s,” “sh” and “t” phonemes sound in relation to the others. Then turn on your system and see how well a program source compares to the real person in front of you. Most likely you’ll hear right away that the voices from the program sound unnatural. Sure, different voices will sound different, but the relative level of the sibilants should be similar to the live voice.
Obviously, it’s impossible to accomplish an EQ adjustment that will make voices sound completely natural in all instances, just like a house curve will not always deliver perfect sound quality (see article linked in first paragraph). Once again, we’re at the mercy of the program’s sound mixer. Even if your speakers are capable of reproducing voices indistinguishable from the real thing, you’ll seldom get such a thing from programming.
A quick and easy faux X curve
Unfortunately, I haven’t found a perfect answer for this problem. The best thing I’ve come up with is a pre-set shelving filter on my center channel equalizer hinged at about 4.5 kHz and cut 5-6 dB - in short, a kind of X curve for the center speaker. This filter allows me to easily switch between flat response (which restores some “life” to muffled sibilants) and attenuated highs (which takes the “sizzle” out of exaggerated sibilants). The hinge (a.k.a. “turnover”) frequency for the shelving filter isn’t critical and can be set according to what sounds best with your speakers. A shelving filter doesn’t continually drop at higher frequencies as the X curve does, but levels off to flat response (see picture below). However, this won’t matter since voice fundamentals don’t extend beyond 7.5 kHz anyway. Besides, there may be other sounds, harmonics and sound effects in the center speaker that extend beyond 7.5 kHz, and we want to be able to hear them.
As luck would have it, most receivers’ treble controls are shelving filters, so this adjustment should be readily available for most people. Easy access to quickly change from one setting to another may be different story, however. (Such are the benefits of outboard parametric equalization over navigating cumbersome menus.) If you’re fortunate enough to have adjustable frequency settings for your treble control, you will probably want to set it no higher than about 5 kHz. As the picture above shows, shelving filters begin their action well beyond the turnover frequency (represented by the vertical line), and the action is forced further out as gain (boost or cut) increases. Be forewarned though, unless your receiver’s manual specifically indicates dedicated center-channel EQ is available, any tone-control adjustments will affect all three front speakers, and perhaps even the rear speakers as well.
If your receiver’s treble control is the rare one with a bandpass filter with adjustable center frequencies instead of a shelving filter, setting it somewhere between 6-9 kHz will do the trick.
As noted, it’s impossible to accomplish an EQ adjustment that will always make voices sound natural. This “A or B” method isn’t perfect, but I’ve found that one EQ setting or the other will deliver acceptable-sounding voices for most program material.
Is the film industry's X curve suitable for home theater?-shelving-filters.jpg
post #3 of 3 Old 05-29-09, 05:53 AM Thread Starter
curve , film , home , industry , suitable , theater
