Using REW for a music studio... - Home Theater Forum and Systems -
post #1 of 6 Old 10-24-09, 06:21 AM Thread Starter
It seems that REW was made for home theater...but that people are using it music studios as well.
I am going to be setting up my room both for creating/recording music and later on as a home theater room.
I know that people use REW to help identify how they need to acoustically treat their room ( or at least thats what i have read), which is what i need to do.
The help section is centered around home theater and using a sub, BFD, EQ etc.. I know i will at least need a sound meter like the radio shack or the galaxy and an external sound, because i am using a laptop...correct?
So what i want to do is set up my 2 monitors and laptop, and use REW to determine where and what i need to acoustically treat my room.
My question is....
What all do i need? SPL meter, external sound card and mic like the ECM8000 and nothing else?
takman is offline
post #2 of 6 Old 10-24-09, 07:06 AM
Re: Using REW for a music studio...
That's basically it. You do require a mic preamp with the mic.
Read and become familiar with the REW HELP files and the REW Cabling and Connections Basics.
Also note the REW information Index and the Download Page.
brucek is offline
post #3 of 6 Old 10-24-09, 09:17 AM Thread Starter
yea, i did read thru a lot that..
i just was unsure about what equipment was needed and what wasnt since im not running a sub.
thanks a lot for the help.
takman is offline
post #4 of 6 Old 10-27-09, 02:40 AM
Same equipment, you just ignore the parts about using a sub....
I found the connections page confusing looking (music studio here too) as I never use mini- jack splitters and such like.
I've plugged it the following way.
Mic - ECM8000 - Pre amp - Soundcard - USB to computer - Soundcard to powered speakers.
I've taped my SPL meter on top of my test mic, not sure if this is usual but it's how I've done it. (If I'm doing something wrong let me know!).
To be honest I found it a bit embarrassing when I looked at the diagrams and struggled a bit, I can wire a patchbay fine!
assemblyworker is offline
post #5 of 6 Old 10-27-09, 03:18 PM
New Member
Hey, I think I'm doing the same thing you are. And I wouldn't be embarrassed, those instruction might make sense to an acoustician or audiophile, but if you are like me, a simple musician who enjoys recording, WAY too much.
I came here looking for a step by step when I saw your post and I'll tell you what I did and really improved my room, though I'm not sure it's entirely correct, maybe just lucky.
I bought the RS SPL, the digital one and hooked its RCA output to one of my my Soundcard inputs, which I assume provides info to REW when it's metering that input.
I set the SPL up as directed, at head level 20 degrees to get both monitors equally.
In REW I went into the settings, in the Soundcard tab I set the top output slot to the soundcard hooked to my monitors (a Delta 66 in my case) despite the directions saying not to, then set the top input to the Deltas inputs where I had the cable from the SPL going. I set the levels section to use main speakers instead of subwoofers, tuned on the SPL to 80, then hit measure and listened to noise. It took a bit of fiddling but I eventually had the SPL sending back a signal to the input, which shows on the meter, though a pretty low signal until I cranked the monitors pretty high. The SPL was showing like 86db and I thought I was supposed to be setting levels to 75db, per the instructions, but that didn't give me enough signal going back to REW (the software told me this at some point, it wants somewhere between -24db and -8db I think). I think I adjusted the Sweep Level to do this.
The other thing I did in settings is go to mic/meter section and, after downloading the .cal file for my SPL meter, browsing to it and getting it loaded up. Check the c Weighing and be sure the SPL has this option selected too.
Then back to the main page, I just hit Measure, checked the levels (I think this is where I was told to go back and raise the input level, which a may or may not have done correctly). Then I hit start measuring. It was a very fast sweeping signal, and it was done. It gave my a curve I assume represents the SPL at every frequency it measures.
THEN, using that result, which is shown on the left with a date and time. In the Target Settings on the left of the screen I set Speaker type to Full Range, and I think I set target level to the same number as my SPL was reading when I took the measurements. In filter task I didn't change anything and hit Find Peaks which gave me a list that told me where the peaks were in the acoustics of my room, and how many decibels over a flat response for each of those frequencies (ion my case it gave me 4). I knew my room had a crazy spike somewhere and it showed up right away, I think at 120hz it was 17db over the target.
So, having this info, I went into my DAW and created an EQ preset to put into the main output channels to compensate for the room's resonances for use when I'm monitoring with my speakers, basically cutting the frequencies exactly the amount REW showed were out of whack. When I tried it out I was pretty amazed at how much better it sounded and how much clearer.
Now, this is how I did it. But I would say this is more of a question response than an instructional one, because I'm wondering if I did it right. The crazy hookups the instructions show seem to be for a much more complex set of measurements than would be necessary for "tuning" a recording room. I can't even figure out what all that splitting and cabling is for, it seems like measuring the resonances of a room are more straight-forward. On the other hand, it seems like what I did, the actual measuring and analyzing, was way to simple. A very quick sweep, that's it? Also, I don't think I measured the full range, just up to 200hz, but then maybe that doesn't really matter much. I'm going to poke around a bit more, maybe there are other tests.
And I would really like to see another test having done the EQ correction, maybe to fine tune a little, but can't figure out how that would happen without an external EQ which I don't have.
anyway, I hope this helps, and I hope someone will let me know if I did this right after all. Cheers.
jimminy121212 is offline
post #6 of 6 Old 10-27-09, 06:32 PM
It's fairly simple.
Most computer soundcards use stereo 1/8" jacks. A stereo plug that splits that signal into its left and right channels is required, since REW only uses a single calibrated channel to output to your receiver or active monitors, and a single calibrated channel for the microphone or SPL meter.
I urge you to read and become familiar with the REW HELP files.
brucek is offline
music , rew , studio
