| REW Forum first tryDiscuss first try in the Subwoofer Equalization | Calibration forum; first try sub only 0deg
sub and mains 0deg
sub and mains 180deg
notes: this is in 742 pixel width, everytime I ... |
| | #1 (Link) | |||
| first try sub only 0deg ![]() sub and mains 0deg ![]() sub and mains 180deg ![]() notes: this is in 742 pixel width, everytime I click ok, the REW changes the 800 I wrote back to 742 no smoothing I used the first 3 channels (do I have to use the one labelled sub?) questions: (please guide me on this one) by the looks of it, my sub should be set at 180 right? do I set the cutoff the same as my crossover setting? Last edited by mike c; 05-16-06 at 12:07 AM. | |||
| | #2 (Link) | |||
| | Re: first try Forget about the mains for now and let's just look at the sub only at 0 degrees and if you want 90 and 180 degrees out of phase. You need to raise your measurement level up though... it looks like you are measuring at a level of about 60-65db. Bump it on up to 80db. Try setting the image to 850px wide and then save it. Set your axis limits as follows: ![]() | |||
| | #3 (Link) | |||
| Re: first try i did the 45-105 15-200 axis thing but I found out that since my monitor display is set to 1024 x 768 ... max size I can save the graph is 742. if I increase monitor display settings, I am able to save the graph to a wider pixel size. anyway, here is my 2nd try first one is: 0deg (sub PEQ deactivated) second one is: 0deg (sub PEQ activated) | |||
