Interrupting Impulse Response - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Interrupting Impulse Response in the Subwoofer Equalization | Calibration forum; Interrupting Impulse Response Hi, I was reading some of the other impulse threads trying to figure out my graph. I am gathering that ...
Old 02-16-07, 02:58 PM   #1 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
Hi, I was reading some of the other impulse threads trying to figure out my graph. I am gathering that when measuring the impulse response we are looking at reflection points and time it takes to reach the mic. Correct? If so, what are we looking for a huge spike? Should I be tring to achieve a smooth as possible pattern close the the zero line?
One thing I noticed is when I moved my speakers back closer to the wall my spike at around 5ms droped. Another thing that is on the graphs I posted below, there is a difference of 15ms from the start of the spikes in the right speaker as apposed to the left speaker. What does this mean?
There is no acoustic treatments as of yet. I am planning on putting up some traps in the corners and first reflection point panels. The room is 14 feet wide and is open to the kitchen. So I have no back wall unless you are counting the back of the kitchen as my back wall.Which is around 55 or so feet away. I have also put the filtered respones of all speakers. Looks likes its finally time to order that BFD.
Old 02-19-07, 05:44 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Interrupting Impulse Response
No replies to this? Are Frankie and I the only ones who want to know something about impulse response?
Old 02-20-07, 03:21 AM   #3 (Link)
Alias: Mike Bentz
Loc: Chicago
DrWho's Avatar
User: #2782
Since: Sep 2006
DrWho is online now
Could you post the impulse responses with dB FS? It'd be easier to read. It's the Energy Time Curves that you wanna plot in %FS and will have more meaning as it pertains to acoustical treatment.
Basically, the impulse response is showing you the magnitude of sound pressure level as it changes with time. Everything you see to the left of the impulse peak (which sould be centered at time=0) is going to be distortion. Basically the program sends a sweep to the speakers to ensure that they play every frequency and then squishes the response back together - pretending as if every note played at the same time. The result of this is that higher frequencies present when the lower frequencies are playing will get shifted to the left - arriving before that frequency should be arriving. So basically everything to the left can be ignored.
To the right, we're going to see all sorts of things. We'll see the arrival-time differences between drivers, any undamped resonances in the drivers/cabinet, reflections throughout the room, and even resonances of the room.
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 02-20-07, 08:38 PM   #4 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
Hi DrWho
Here are the Graphs with dB FS for impulse. I am not sure I am using the correct scale, so I hope this is ok. I also posted the Time energy graphs for left and right speaker. The Left Speaker is in blue and the right is in red.
File Type: jpg impulse left speaker in dbfs 2-16-2007.jpg (106.5 KB, 37 views)
File Type: jpg impulse right speaker in dbfs 2-16-2007.jpg (107.3 KB, 37 views)
Old 02-20-07, 09:22 PM   #5 (Link)
Alias: Mike Bentz
Loc: Chicago
DrWho's Avatar
User: #2782
Since: Sep 2006
DrWho is online now
Do you hear clipping or distortion upon playback of the frequency sweeps? That behavior to the left of time = 0 is not normal at all. In fact, your ETC for the left speaker looks exceptionally bad...is there anything nearby that might be obstructing its sound? I almost wonder if you didn't bump the mic or anything while taking the measurement. You could always deconvolve your impulse response back into the measured data and listen for any abnormal sounds upon playback that might be contributing to the wierd data.
If you could post your REW file I could do the deconvolving thing and listen for whatever craziness might be going on.
-Mike Bentz
Old 02-20-07, 11:10 PM   #6 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
DrWho wrote: View Post
Not quite sure I follow what you mean by deconvolve .Is the REW file you are requesting the file with .mdat extention? If so the forum won't let me upload it do to the size.
I got back kind of late from my meeting so tomorrow evening I will run some tests to make sure I am gathering good data. I am thinking of swaping speakers side to side and retest. Here is a photo of my room, as you can see the only thing kind of it front of the speaker is the couch and end table.
Old 02-21-07, 09:50 PM   #7 (Link)
Alias: Frankie
Loc: Manteca CA
User: #5244
Since: Jan 2007
Ciscokid is offline
Ok got some time to run some tests. First off I recalibrated my mic and sound card file. I reran sweeps for both speakers. The left and right speakers still have the same impulse graph. I tried swapping speakers. That did not change anything.
If you look in the photo I posted,I moved the left speaker closer to the center channel and that moved my impulse starting point closer to zero. So I am not sure what that means if anything. I posted both energy graphs for the left speaker. The first one is in its normal location. The second one I placed the speaker just to the left of the center channel. The 3rd is just the impulse with it close to the center channel.
I did not hear any clipping during any of the sweeps I ran. I am still curious what you mean by the deconvolving. Please let me know what file you need. Thanks for all your help.
Similar Threads
impulse response.... Hakka REW Forum 12 01-06-08 04:32 PM
Questions about my subs response. Jerm357 REW Forum 20 03-23-07 09:01 PM
PB12+ Room Response daxie REW Forum 24 01-30-07 01:24 AM
Behringer UB802 response brucek SPL Meters | Mic's | Calibration | Sound Cards 6 11-20-06 07:02 AM
Response graph Blackwidow REW Forum 23 11-03-06 01:51 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
