Calibration Mic Calibration? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Calibration Mic Calibration? in the Subwoofer Equalization | Calibration forum; Calibration Mic Calibration? I just read the sticky about mic calibration, and it appears that the technique involves comparing our sample mic's response ...
Old 02-18-07, 01:26 AM   #1 (Link)
Alias: Andre H.
User: #6401
andreh is offline
I just read the sticky about mic calibration, and it appears that the technique involves comparing our sample mic's response against that of a reference mic.
My question is: how is the reference mic calibrated? No mic has perfectly flat frequency response. Maybe it's considerd "close enough," or is there some other approach used that's more scientific?
Andre
Old 02-18-07, 01:46 AM   #2 (Link)
Alias: Andre H.
User: #6401
andreh is offline
Re: Calibration Mic Calibration?
Here are the specs for the mic that Kim Girardin apparently uses for his calibration readings. According to this chart, it's either the 7016 or the 7017 (if it's a 1/4 model as is stated in the Mic Calibration sticky):
http://www.acopacific.com/chart.html
Here's a chart of "typical" frequency responses for these mic's:
http://www.acopacific.com/micdetal.html
As you can see, they're pretty flat; the 7017 is a ruler past 20k, while the 7016 might have the smallest bump (<2dB) ~13k and then a similarly small drop ~18k.
I still wonder, though, if any compensation is made for the unique response of Kim's actual mic. If it's even close to these typical reponses then compensation is probably not necessary, but inquiring minds want to know...
Andre
Old 02-19-07, 02:33 PM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
We are somewhat at the mercy of Kim's mic being accurate enough to satisfy us, more particularly in the lower 10-200Hz range.
Old 02-19-07, 11:40 PM   #4 (Link)
Alias: Andre H.
User: #6401
andreh is offline
Sonnie wrote: View Post
I'm sure Kim does a great job of providng very accurate results...it's just my analytical side that's curious about the mic's calibration.
I'm not just calibarting my sub, though, so the higher frequencies are of interest to me as well.
Andre
Similar Threads
Order of Calibration? John_Williams REW Forum 2 10-21-06 07:56 AM
Mic Calibration - non USA ? Alaric SPL Meters | Mic's | Calibration | Sound Cards 4 05-12-06 05:06 AM
Help please - Calibration Trouble zorax2 REW Forum 9 04-28-06 11:10 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199
