| REW Forum Low measurement with REW?Discuss Low measurement with REW? in the Equalization | Calibration forum; Low measurement with REW? First let me apologize if my graph is not formatted correctly in regards to the db levels (but that me ... |
Views: 938 - Replies: 33
| Low measurement with REW? First let me apologize if my graph is not formatted correctly in regards to the db levels (but that me be my issue). I went through the help files and believe I have calibrated the sound card and SPL meter correctly. I loaded the digital cal file for my RS meter. I ran the output of my soundcard to the DSP1100P (in bypass mode) to the amp of my sub. Running a Sonotube TC2000 15". Calibrated the SPL to 75. Ran the measure and the "response" line is way down in the db range. Does it appear that maybe I set something up wrong? Thanks for any help that can be provided. | ||||
| | #5 | ||||
| Re: Low measurement with REW? I went through and deleted the information. Redid the setup. This time I removed the BFD from the loop and ended up with the below information. First shot is of the information from calibrating the sound card and than SPL. The second is the measurement of the sub. I am wondering if the BFD was causing something weird to happen. It was given to me by a friend and I thought I had successfully cleared it memory. | ||||
| | #6 | ||||
| Re: Low measurement with REW? Looks quite normal now. With the BFD, to temporarily turn off the filters, simply push the IN/OUT button so that the green LED is off and the signal should just pass through the BFD with no filters. The filters are engaged when the green LED is on. Either way, for the BFD program that you will be using, be sure to go through and turn each filter to 'OF' and save it. Then you can add your own filters from there. brucek | ||||
| | #8 | ||||
| Re: Low measurement with REW? Well here is my first attempt at tweaking the sub with the BFD. I have a dip around 60 but cannot get it any better. I made the below filters for it. Not sure if I can clean the dip around 60 up any better. If anyone with more expereince with the BFD has any advice on this that would be great. 20 + 2 25 + 2 40 - 3 63 + 13 80 - 7 | ||||
| | #9 | |||||
| Re: Low measurement with REW? Quote:
It's usually best to EQ the sub alone first, then add the mains to tweak any problems around the crossover area. brucek | |||||
| | #11 | ||||
| Re: Low measurement with REW? Also, please notice that your measured sub (green line in graph) response is mostly found below the "target level" (blue line on graph). With this situation, the REW program sees all of this (mostly everything up to 60 Hz) as dips in the frequency response and won't do anything to fix it. To make better use of the program, try turning up the volume / gain knob on your sub (not your receiver) and re-measuring the response. Once the measured response (green line) is mostly above the target level (blue line), then have REW suggest filters to cut the response at the high spot and bring everything down to a smooth level. | ||||
| | #12 | ||||
| Re: Low measurement with REW? I was not aware that REW could make suggestions like that. I have everything disconnected right now (measureing equiptment) but I will be moving the sub to another location, so when I move it I will rerun everything. Thanks. | ||||
| | #13 | |||||
brucek | |||||
| | #14 | ||||
| Re: Low measurement with REW? Bruce, I have a follow up question for you. I do apologize up front if this is a really bad question. You had mentioned to add in the mains and do some testing. In the REW help files it shows to connect into "Aux in" if available. I have a Denon 3803 which does have analog in for 5.1. My question is, if I use these, it seems I would have to do one main at a time. Can I connect into either the analog "cd" or "phono" to get both mains at the same time? Also, I have removed the filter for "+13" at 60. Thanks. | ||||
| | #15 | |||||
When you connect to AUX (or CD for that matter), and place your receiver in Stereo mode (with the crossover enabled), then the sub and mains will be on, and the center and surrounds will be off. With this setup then, to test the sub alone, you remove the mains by shutting off the mains amp (if you have one) or by disconnecting the mains speaker wires. To add in the mains, you connect the speaker wires. Of course you do this disconnecting and connecting with the power off while ensuring the wires don't short. brucek | |||||
| | #17 | ||||
| Re: Low measurement with REW? Bruce, I have relocated the sub to it permanent place and measured again. The first graph is with no filter and the second is with two filters (40 -4db and 50 -2 db). If you don’t mind making an recommendations-comments on this. Also, I am not using a midi cable to connect over. If I did would this provide anymore functionality with other freq's not all ready in the BFD? Thanks. | ||||
| | #18 | ||||||
brucek | ||||||
| | #19 | ||||
| Re: Low measurement with REW? What I have been doing it setting the sub amp so when I run the "calibrate spl" I am close to 75. I will set it be 80 and try again. One other question, should be trying to use the "fine" to get a freq around 45 and pull it down so I am not just pulling down 40 and 50? Thanks again. | ||||
| | #20 | ||||||
brucek | ||||||
| | #22 | ||||
| Re: Low measurement with REW? Bruce, Please forgive my ignorance but I would just like to verify my steps are correct. 1) BFD in bypass 2) click SPL meter button 3) set sub amp so output is 75db on meter 4) run set target level 5) run measurement 6) find peaks 7) program filters that are shown At anytime do I need to redo the set target level? Thanks again. | ||||
| | #23 | ||||
| Re: Low measurement with REW? After you've set the subwoofer output trim in your receiver, then use your receivers test tones to roughly match the subwoofers level with the rest of the speakers. The sub level would be set using the sub amplifiers level control. 1) The BFD should have its filters either in OF mode or bypassed (IN/OUT green LED off) to obtain a raw without filters measurement. 2) Ensure the soundcard and meter calibration files are loaded in REW, cutoff set at crossover setting (i.e. 80Hz). 3) REW Settings ICON. - Check Levels routine, using receivers master volume control to set 75dB on SPL meter. - Calibrate SPL routine. - Set Target Level. 4) Measure, find peaks, assign filters, adjust filters manually to get best result. You can raise or lower the target level manually to get more of your response above the target line if you want. 5) Enter filters into BFD and then remeasure to see results. (with filters engaged) brucek | ||||
| | #25 | |||||
brucek | |||||
