| REW Forum My first measurement graph, what is wrong??Discuss My first measurement graph, what is wrong?? in the Equalization | Calibration forum; My first measurement graph, what is wrong?? I finally calibrated everything. I tried my first measure, and here is the graph I get ??? What is wrong ... |
Views: 736 - Replies: 8
| | #2 | |||||
| Re: My first measurement graph, what is wrong?? Quote:
Post all graphs with a vertical scale of 45dB to 105dB and a horizontal scale of 15Hz to 200Hz. Set the sweep limit to 200Hz when measuring a subwoofer. brucek | |||||
| | #3 | ||||
| Re: My first measurement graph, what is wrong?? From your other post re your soundcard (using Wave for both output and input) I would guess the problem is you have the output signal feeding directly back in as the input, so you are seeing the inverse C response on top of the flat response which results from using the wave output also as the input to REW. You will need to get your soundcard set up so that the SPL meter signal is getting through as an input. | ||||
| | #5 | ||||
| Re: My first measurement graph, what is wrong?? Can you post a link to the website for your soundcard? | ||||
| | #7 | ||||
| Re: My first measurement graph, what is wrong?? Step by step instructions on posting graphs are in the sticky threads, but you would want to start a new thread when you get your graphs ready... ![]() | ||||
| | #8 | ||||
| Re: My first measurement graph, what is wrong?? Hey christian, Just wondered if you got things firgured out? I had terrible problems the first day with my soundcard. I had it set wrong in an easly overlooked setting. I always look forward to seeing new graphs posted ![]() Good Luck John | ||||
