REW Forum
50 hz dip
Discuss 50 hz dip in the Equalization | Calibration forum; 50 hz dip I have a large 53hz dip in the middle of my room how do i correct it I have a ...
Views: 676 - Replies: 2
Old 02-22-07, 05:29 PM   #1
Alias: jwhite
Loc: Houston,Texas
User: #6296
  jwhite8086 is offline
50 hz dip
I have a large 53hz dip in the middle of my room how do i correct it I have a svs pb10 and bfd
thanks
Old 02-22-07, 06:01 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: 50 hz dip
How big is the dip in decibels? And how wide the bandwidth?
You can increase the output of your sub till the bottom of that trough is roughly at the target point. Then, quash the rest of the frequency response until you hit your target.
It's generally not a good idea to boost, but I'll do it in a pinch if it's only a couple dB.
-- Otto
Old 02-23-07, 02:54 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: 50 hz dip
Your first options are to move where you sit or where your sub sits. If you don't need to sit in the middle of the room to listen, ignore it. If that's an important listening position, try moving your sub. Is the dip present across the width of the room? If so, try placing the sub against the wall half way along the length, if the dip is down the length try placing the sub against the wall half way across the width. You will lose some overall output compared to having the sub in a corner, though. If your room is not rectangular try the sub in each corner to see which gives the smoothest overall response.
