REW Forum
Second Time is the Charm with new REW
Discuss Second Time is the Charm with new REW in the Equalization | Calibration forum; Second Time is the Charm with new REW I had a terrible first experience with REW this summer. I was unable to get any useful measurements because of ...
Views: 641 - Replies: 5
Old 02-23-07, 08:39 AM   #1
Alias: Wade
adogand6kids's Avatar
Loc: Minot, North Dakota
User: #1793
  adogand6kids is offline
I had a terrible first experience with REW this summer. I was unable to get any useful measurements because of a horrible whining noise the system generated. Despite several suggestions from other forum members, it didn't go away and I gave up. I started looking at the REW forum again when the new version of REW was released. I love the new look and the help files are even better. I also found a suggestion to run Dell laptops on battery power only and not have them plugged in to an electrical outlet. I am not sure what made the difference, but I tried everything again yesterday and it went as smooth as you could imagine. I had a corrected room response in about one hour. I can't believe how well things worked. The new REW is much more understandable to me. Thank you John for continuing to work on improving this great tool. Have a look at my uncorrected (pre-BFD) and corrected (post-BFD) graphs and let me know what you think. I only did subwoofer response last night, not sub plus mains.
This is the uncorrected room response
Name:  jpeg of uncorrected room response feb 2007.jpg
This is after BFD filtering the room response. I had to turn the volume up for the second measurement because I had too low a signal after I removed the 14 decibel peak at 42 Hz.
Name:  jpeg of corrected room response feb 2007.jpg
Unfortunately after I got it looking like this, I had to go to bed before I was able to do any subjective listening. That's on the menu for tonight. It went so well that I may try loading a housecurve on another pre-set and seeing if I like that sound better.
Any feedback on the graphs? I left the response a bit higher at 20 Hz on purpose. Would anyone recommend that I try to get it flat there as well?
Old 02-23-07, 08:54 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Second Time is the Charm with new REW
I think the after graph will take to a housecurve very well. You did a good job.
I would of course, add the mains when you get the time and make sure that the crossover area doesn't get messed up.
Old 02-24-07, 08:22 PM   #3
Alias: Bones
User: #2727
Since: Sep 2006
  tdamocles is offline
How big is the room you have this sub in?
Old 02-24-07, 10:23 PM   #4
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Good job Wade... very good...
Old 02-25-07, 11:53 AM   #5
Silver Supporter
Alias: John
Loc: Lafayette, IN
User: #6005
Since: Jan 2007
  cellexjohn is offline
Wade,
Now that you have had time to listen to the changes, what do you think? I ended up with a 5dB peak from 80 to 30 for my house curve. That made it more exciting in the lower region.
Enjoy
John
Old 02-26-07, 12:36 PM   #6
Alias: Wade
User: #1793
The room is 13 ft wide, 38 ft long and 6 ft 8 in high for a total size of about 3,300 cubic feet.
Unfortunately I have been working all weekend and have spent a second listening to the system. Tonight I might get some time. I'll post when I've had a chance. I'ld like to try listening to a pure flat response and comparing it to a house curve. That will probably be later in the week.
Yep, that's on my "to do" list. I'll post the graphs when I get them done.
Thanks for the feedback.
