REW Forum
"No peaks to correct" message from REW
Discuss "No peaks to correct" message from REW in the Equalization | Calibration forum; "No peaks to correct" message from REW Just for snicks, I thought I would re-run REW (4.0) on my system which I had already equalized a while ...
Views: 555 - Replies: 2
Old 02-24-07, 10:47 AM   #1
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
  Mitch G is offline
Just for snicks, I thought I would re-run REW (4.0) on my system which I had already equalized a while back.
After making the measurement - which turned out exactly the same as the first time - I clicked on the "Assign Filters" option under Filter Tasks and was told that there are "No peaks to correct."
In REW 3.x, I was able to get a set of filters created.
So, I'm wondering if there are some thresholds I can play with to force REW to come up with some filters.
Thanks,
Mitch
Old 02-24-07, 11:21 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: "No peaks to correct" message from REW
After your measurement is done, you simply adjust the Target Level thumbwheel up or down to get more or less response information considered by the Find Peaks function....
Old 02-25-07, 08:15 PM   #3
Alias: Bri
Loc: San Jose
User: #215
  cyberbri is offline
Yes, the "find peaks" will find peaks above whatever your target level is set to.
My HT Gallery (Updated pics of my setup and room treatments)
My REW measurements with bass traps and BFD eq
