REW Forum
Microphone for EQ Room Wizard
Discuss Microphone for EQ Room Wizard in the Equalization | Calibration forum; Microphone for EQ Room Wizard Can someone tell me what type of Microphone is best to use when using the EQ Room Wizard to evaluate ...
Views: 1291 - Replies: 23
Old 02-27-07, 08:01 PM   #1
Carter Asbill
Inactive
Alias:
User: #
Posts: n/a
Smile Microphone for EQ Room Wizard
Can someone tell me what type of Microphone is best to use when using the EQ Room Wizard to evaluate a listening room and what quality Mic will do?
I also would appreciate any recommendations on a Mic.
Thanks very much.
Carter
Old 02-27-07, 08:38 PM   #2
Bronze Supporter
Alias: Julien
Loc: Western NC
User: #4401
Since: Nov 2006
  Julien43 is offline
Re: Microphone for EQ Room Wizard
While it is certainly not the "best" measurement microphone, the Behringer ECM 8000 is highly recommended
It is, basically flat, inexpensive and there is a calibration file for that mic
It does require phantom power, so the cost of an mic pre may have to be added to the bottom line
Julien
Old 02-27-07, 09:16 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Welcome to the Forum, Carter!
The Behringer is a good mic (in conjunction with the calibration file) if you want reasonably accurate full range readings out to 20 kHz or so. If all you want to do is measure your subwoofers, the venerable Radio Shack SPL meter will do. Most of us already have one (you should too, if you don’t already).
Old 03-01-07, 11:33 PM   #4
rabiddawgs
Inactive
Alias:
User: #
Posts: n/a
i also have this question. im new to this and not really sure what im doing. but my brother has a mic that he uses for his band. would this work? its not a high priced one but its not a cheap one either.
Old 03-02-07, 04:20 AM   #5
Alias: brucek
User: #6
  brucek is offline
would this work?
No, unless you have a calibration file for it or can verify that it is perfectly flat over the frequencies of interest.
Old 03-02-07, 08:57 PM   #6
rabiddawgs
Inactive
Alias:
User: #
Posts: n/a
where would i go to find out if there is a calibration file for it.
Old 03-02-07, 09:23 PM   #7
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
You probably would not find a calibration file for it, not to mention it probably isn't a measurement mic, although it might still work if you had it calibrated.
Old 03-02-07, 10:58 PM   #8
Alias: Dan
Loc: Australia
User: #359
  Danny is offline
What type of mic is it, you could probably go to the manufacturer site and check it out, i know the Shures have the responses
Old 03-05-07, 10:17 PM   #9
rabiddawgs
Inactive
Alias:
User: #
Posts: n/a
im not sure what kind it is i will have to give my brother a call and find out.
are there any lower cost alternatives. i cant justify spending that much just for a mic to use once or maybe twice.
Old 03-12-07, 01:49 PM   #10
dmccombs
Inactive
Alias:
User: #
Posts: n/a
I am getting a ECM 8000 with my new SMS-1. Will the SMS-1 act as a 'mic pre'?
I would like to use the ECM 8000 with REW to see what is happening in my room (above the sub range).
Julien43 wrote: View Post
While it is certainly not the "best" measurement microphone, the Behringer ECM 8000 is highly recommended. It is, basically flat, inexpensive and there is a calibration file for that mic
Old 03-12-07, 02:11 PM   #11
Alias: brucek
User: #6
  brucek is offline
The SMS-1 comes with its own microphone and internal calibration file. I don't know if its an electret condenser type like the ECM (that requires a phantom voltage). Why would you purchase an ECM8000 to use with the SMS ?
Old 03-12-07, 02:23 PM   #12
dmccombs
Inactive
Alias:
User: #
Posts: n/a
Bruce,
I think the mic that comes with the SMS-1 is a ECM 8000.
Darrell
Old 03-12-07, 02:56 PM   #13
Alias: brucek
User: #6
  brucek is offline
Interesting, I didn't know that.
I can't see anywhere in the pdf of the sms users manual where they breakout the microphone preamp to transmit the information to external devices. Then you might wonder, even if they did, is the calibration applied at that point anyway.....
You'll need a behringer mic preamp to use the ECM8000 with REW....
Old 03-12-07, 03:02 PM   #14
dmccombs
Inactive
Alias:
User: #
Posts: n/a
I see the SMS-1 has a pass through, but I don't know if this will do it.
Old 03-12-07, 03:10 PM   #15
Alias: brucek
User: #6
  brucek is offline
The pass-through is for feeding the un-equalized line level from the SMS-1 to a second SMS-1 unit.
Old 03-12-07, 03:35 PM   #16
dmccombs
Inactive
Alias:
User: #
Posts: n/a
What about using the LFE Out?
Old 03-12-07, 03:57 PM   #17
Alias: brucek
User: #6
  brucek is offline
That's the equalized line-level signal to your subwoofer. (in both balanced (XLR) and unbalanced (RCA) connectors....
Old 03-12-07, 04:49 PM   #18
dmccombs
Inactive
Alias:
User: #
Posts: n/a
So what kind of mic pre do I need to buy for a EMC 8000?
Thanks for the input Bruce. While I may not like the answers, I do appreciate your help. ;-)
I will have a laptop, RS Meter, SMS-1, EMC 8000, and I will still have to buy a mic pre to measure above 500-1k hz?
What about an intgrated amp that has an XLR input? I have one of those.
Otherwise, what kind of mic pre do I need to buy for a EMC 8000?
Old 03-12-07, 05:53 PM   #19
Alias: brucek
User: #6
  brucek is offline
No, you need a proper low level microphone preamp with integrated phantom supply to use with the ECM8000.
The Behringer XENYX 802 preamp is the one that everyone uses. It has the pahantom voltage required for the ECM8000.
The model they used to sell before they renamed it XENYX was the EURORACK 802 (identical product really). You may see these on e-bay. Its the model I have.
The XENYX802 retails about $79.
The ECM and 802 preamp with a calibration file (on the shack site) is a fairly accurate combo that is good for all frequencies...
Old 03-14-07, 10:28 PM   #20
mace
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
You can also get a the M-Audio brand "AudioBuddy" for a nice, clean, low noise mic pre-amp (with phantom power). it is two channel as well, although phantom power is either "on" or "off" for both channels (they can't be controlled seperately). I have had good luck with this little box (runs off of AC power) and the ECM-8000 as well as several brands of instrument/voice mics for recording into GarageBand. I'd swear when I got it 2 years ago it was only $30 but maybe my memory is fried! If I really did pay $80 for it I wish I would've gotten the Bheringer.
http://www.zzounds.com/item--THKMIMAB0
Mace
Old 03-14-07, 11:53 PM   #21
Owner
  Sonnie is offline
That one looks like it functions similarly to the MIC100 from Behringer, which is only $39. Not sure why we would be using it anyway... it has phantom power.
Old 03-15-07, 10:52 AM   #22
Alias: brucek
User: #6
  brucek is offline
The MIC100 is a tube preamp. Its response would have to be considered in addition to the ECM calibration. Not really suitable. Whenever you read the word 'warm' when describing a product, besides the harmonics implication, insert the words ' response'....
Old 03-21-07, 11:04 PM   #23
mace
Inactive
Alias:
User: #
Posts: n/a
Sonnie wrote: View Post
Doesn't the ECM8000 require phantom power?
Mace
Old 03-21-07, 11:14 PM   #24
Owner
  Sonnie is offline
lol... I didn't think about it that way. Some folks do like "warm" though...
mace wrote: View Post
Yes!
