Check levels too low - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Check levels too low in the Subwoofer Equalization | Calibration forum; Check levels too low Another of the endless parade of noob's needing help with REW here! My problem arises when I check levels after ...
Old 02-19-07, 08:23 PM   #1 (Link)
Alias: Tig
Loc: Winnipeg
User: #6678
CdnTiger is offline
Another of the endless parade of noob's needing help with REW here! My problem arises when I check levels after calibrating my soundcard. I adjust the receiver's volume to get 75dB on the RS meter, only to find the input level in REW is around -35dB, and I can't figure out how to change that without also changing the volume of the pink noise being output. Even if I do max out my soundcard's settings, the level still can't be brought up to -18.
Some background info:
- soundcard is a Creative Audio Emu 0404 with the Patchmix software installed
- RS meter is an old model 42-3019 (older than what is called old on this forum!)
- I get a nice looking soundcard curve and the corrected curve is perfectly flat as its supposed to be
- the Emu 0404 has separate input and output for each of the left and right channels, so I don't think it's a problem of the input not being sent to the right channel. Interestingly, by switching between the left/right channels within REW, the input level doesn't change at all... zip, zilch, nada, etc. So I tried hooking up the RS meter to the other physical soundcard input (left), but this just dropped the input level by about 60dB (again for both the left/right channel settings within REW).
My hunch is that I need a line amplifier between the RS meter and my soundcard, which seems odd considering I haven't come across this situation while searching the forums. The other possibility is that I haven't configured Patchmix properly (although I think I have and the fact that I can get good soundcard calibration using loopback seems to confirm this). The reason I haven't completely ruled out incorrect Patchmix settings is I can't figure out how to change the input level. Anything I do simply alters the signal being sent to the receiver, causing my actual dB level to change.
Note that my input levels are about -37dB using the subwoofer pink noise, and -35dB using the main speakers & sub setting. I can get a frequency response curve that looks like it may be a good representation of my system, but I'm losing a lot of dynamics by having my check levels so low, aren't I?
Any suggestions are appreciated, thanks,
Old 02-19-07, 10:05 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Check levels too low
I would get a meter that there is a valid calibration file for. Even if you got this working, how meaningful are the results if you don't have a calibration file?
Test the meter by plugging it into the AUX input of your receiver. It's a microphone. Does it appear to have ample signal level when you turn the volume up and talk into the mic?
Old 02-20-07, 11:31 PM   #3 (Link)
Alias: Tig
Loc: Winnipeg
User: #6678
CdnTiger is offline
OK, I've now got a new analog RS meter on the way. I was planning on confirming I could get REW to work properly first, but agree that the new meter will provide a little peace of mind that any measurements I make are accurate.
My voice comes through the speaker clearly when hooking my old RS meter to the receiver with the receiver's and RS meter's settings the same as my attempted REW setup. I guess that rules out the need for a line amplifier - my wallet thanks you Bruce! I get to hold off doing this a wee bit longer.
Do many others at the Shack use the 0404 and/or Patchmix? I'm becoming more and more convinced that there's some setting or step I'm missing in getting the soundcard working with REW properly.
Old 02-27-07, 09:44 PM   #4 (Link)
Alias: Tig
Loc: Winnipeg
User: #6678
CdnTiger is offline
Well, yesterday I got both my new RS meter and a reply back from Creative on what I was missing in my soundcard DSP software configuration . In case anyone else runs into the same problem in the future, the 0404 needs two inserts on the PCI In Right strip (assuming you're using the right channel) - a trim pot that allows adjusting the input level from the RS meter and a Send to Wave insert. And this strip should be muted to avoid feedback errors.
REW and my new RS meter now seem to be playing nicely together. Time to experiment . I'm almost kinda disappointed I'll be away on vacation in a couple of days and will have to postpone moving up the REW learning curve. But don't worry, I'll be back posting graphs of my response and looking for advice!
Similar Threads
O'scope for amp levels jokers10 Home Theater Components 5 03-03-07 02:53 PM
REW - sets up right but then "check levels" too low Schwingding REW Forum 16 02-20-07 08:03 AM
Can't get the BFD input levels up high enough monomer BFD Forum 9 12-21-06 11:58 PM
Double check sonosub info rhino2 DIY Subwoofers - Sealed and Ported 5 12-11-06 12:55 PM
soundcard calibration check. terry j REW Forum 0 11-17-06 10:44 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
