M-Audio Fast Track Pro setup help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss M-Audio Fast Track Pro setup help in the Subwoofer Equalization | Calibration forum; M-Audio Fast Track Pro setup help I plan on getting an M-Audio Fast Track Pro external sound card and am confused as to which cable I ...
Old 03-01-07, 08:41 AM   #1 (Link)
New Member
Alias: Mike
Loc: Wichita, KS
User: #6261
737NG is offline
I plan on getting an M-Audio Fast Track Pro external sound card and am confused as to which cable I should get to calibrate the unit with. The unit has balanced inputs AND outputs. Would it be best to use an XLR to 1/4" TRS patch cable?
Old 03-01-07, 10:08 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: M-Audio Fast Track Pro setup help
What type of microphone/meter do you plan to use?
Old 03-01-07, 10:31 AM   #3 (Link)
New Member
Alias: Mike
Loc: Wichita, KS
User: #6261
737NG is offline
I will be using an ECM8000
Old 03-01-07, 11:10 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Ideally with REW, you want to create a soundcard calibration file that is the exact inverse of the combination of input and output circuits you'll be using for measurement. That way, the audio card imitates a perfectly flat response and doesn't influence the room measurement.
With PCI type soundcards we use the line-out looped to the line-in because those are the connections we use to measure with.
In the case of the M-Audio cards where you're using the phantom powered microphone pre-amp as part of the measurement, it is not really possible to include the preamp in the loopback test to produce the soundcard cal file. But, no big deal really in my opinion, because we will have to assume the preamp has a perfect response. That is certainly what we do when we use an ECM8000 with the EURORACK UB802 (which actually does have almost a perfect response for the frequencies of interest).
So, I believe what most people do to create the file is to loop the line-out to the instrument line-in. Since the instrument line-in appears to accept unbalanced 1/4" TS connector plug, then I would loop that to the line-out that you'll be using as part of your measurement (I assume the RCA unbalanced out #1 or #2). So you would need an RCA to 1/4" TS cable for the loopback. Then for the measurement, use the RCA #1 or #2 line-out and the XLR balanced microphone jack for the ECM8000.
Similar Threads
REW with M-Audio Fast Track Pro sonata31 REW Forum 8 10-27-06 07:09 AM
Audio Pro Sub Focus Ilkka Subwoofer Tests 3 07-17-06 02:34 PM
M-Audio Basic Setup Question rolyasm REW Forum 7 07-16-06 12:19 AM
Pro Audio Amps JCD Home Theater Components 22 05-17-06 05:58 PM
Mach 5 Audio
