REW Forum
got my bfd - first graph i need help
Discuss got my bfd - first graph i need help in the Equalization | Calibration forum; got my bfd - first graph i need help Hi all, i have just started using REW 4.0 and have purchased a bfd. The sub i have is a ...
Views: 596 - Replies: 5
Old 03-03-07, 10:31 AM   #1
New Member
Alias: mike
Loc: kirkcaldy
User: #5032
Since: Dec 2006
  miker916 is offline
Hi all,
i have just started using REW 4.0 and have purchased a bfd. The sub i have is a BK Monolith but my first attempt at a graph dosen't look right. The bass looks to tail off a lot after 32Hz. I thought the Monolith would be a much better subwoofer than that? I calibrated the sub @75db using my radioshack spl meter and am using the spl correction file. What can i do to improve the lower end, the sub gain is only at 25% at the moment. I can increase the gain so that the response at 20Hz is on the target line but i get a warning when trying to find peaks and REW wants to add 20 filters to lower the rest of the response. My sub is in the front right corner (only place i can realistically place it). I'm completely new at this game so i apologise in advance if i'm asking some stupid questions, but any help/advice would be greatly appreciated.
Thanks
Mike
Old 03-03-07, 12:08 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: got my bfd - first graph i need help
It’s not really “tailing off” below 32 Hz – you just have a peak there that needs to be dealt with. Eliminate it with the BFD and you’ll have solid response down to 20 Hz.
That’s because at that point the other frequencies are super high.
It doesn’t look like the target line is going to do much for you in this situation – at least not initially. Try setting a couple of filters to pull down those peaks at 32 and 89 Hz, then re-calibrate your levels and take another sweep. At that point you should closer to the target line, and you can apply other filters to finish up. Remember the idea is to improve response, so don’t over-do the number of filters trying to make it “picture perfect.” IOW, as long as you can get response approximately along the target line, it’ll sound great.
Old 03-03-07, 12:58 PM   #3
New Member
Alias: mike
Loc: kirkcaldy
User: #5032
Since: Dec 2006
  miker916 is offline
Thanks Wayne, i've applied the 2 filters as you suggested, it's looking a lot better already and more importantly sounding much better. Is it a good idea to try and reduce the 80-200 range?
Old 03-03-07, 10:33 PM   #4
Alias: Wayne
Loc: Katy, Texas
User: #8
Just hit those two peaks below 100 Hz and you’ll be about done. However, if you’d like stronger response below 20 Hz, you might work on smoothing down the range between 20-40 Hz.
Old 03-04-07, 01:30 AM   #5
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Hi Mike!
There's never such thing as "stupid questions", everybody's learning everyday! What's the dimentions of your room? Is it a big one?
You equalized FR is fine IMO. Just follow Sir Wayne, and it will be a big win!!
B Rgds
Blaser
Old 03-04-07, 06:54 AM   #6
New Member
Alias: mike
Loc: kirkcaldy
User: #5032
Since: Dec 2006
  miker916 is offline
Thanks guys,
response looks much better now. It really is amazing the difference a BFD and the excellet REW software can make to your sub.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
