REW Forum
My first measurements, please be kind :)
Discuss My first measurements, please be kind :) in the Equalization | Calibration forum; My first measurements, please be kind :) Here are my REW measurements and to my untrained eye, they do not look that bad, opinions? BUT, I took ...
Views: 1328 - Replies: 32
Old 03-08-07, 11:07 PM   #1
Alias: Jim
User: #6255
  vfrjim is offline
My first measurements, Opinions please.
BUT, I took measurements with TrueRTA and they look MUCH different, which one is right? Could someone explain.
I, personally do not like the sound of my room, it is VERY live and my GIK acoustics will be arriving tommorow and will solve much of my problems.
Thanks,
Jim
Old 03-08-07, 11:16 PM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: My first measurements, please be kind :)
Yeah, that REW response is too good to be true! Maybe you have your loopback enabled in your soundcard software? I think it varies from soundcard to soundcard. See if you can find something about in your soundcard's software or in the control panel.
Once you get that taken care of, your results will probably be more like those of TrueRTA.
Good luck!
-- Otto
Old 03-08-07, 11:16 PM   #3
Owner
Loc: L.A. (Lower Bama)
Yeah... I'm not sure what's up with REW there, but something isn't right. I'm sure some of our pros will chime in and lead you in the right direction. Looks like a pretty nasty peak at 40Hz, but that TrueRTA is an awful low measurement.
Old 03-09-07, 08:26 AM   #4
Alias: brucek
User: #6
  brucek is online now
You may have an internal soundcard loopback monitor turned on. Check that. Then be sure you have the soundcard calibration file and the microphone calibration file properly loaded.
When you connect a short from line-in to line-out (as you did to create the soundcard cal), do you get a flat line response (with meter cal file cleared) as you should?
Old 03-09-07, 12:12 PM   #5
Alias: Jim
User: #6255
  vfrjim is offline
brucek wrote: View Post
This is a graph when I loopback the soundcard.
Old 03-09-07, 01:19 PM   #6
Alias: brucek
User: #6
Did you have the meter calibration file cleared and the soundcard calibration file loaded for the test?
edit: If the answer to that is yes, then you have an internal loopback monitor turned on in your soundcard software. If you connect a loopback cable and run a sweep, then the response that shows in the graph should be a flat line (response of the cable). The real response was actually the poor response of the soundcard, but then inversly compensated for by the soundcard cal file, which results in flat.
If an internal loopback is present, then all you see in the graph is the inverse of the soundcard file (which is what you show)...
Old 03-09-07, 07:36 PM   #7
Alias: Jim
User: #6255
  vfrjim is offline
This was a clean install of REW, no meter calibration file (using ECM8000 mic, uncalibrated), soundcard was calibrated in TrueRTA (is this done in REW, if so how? I did not see it in the options).
Old 03-09-07, 08:29 PM   #8
Alias: brucek
User: #6
You require a microphone calibration file for the ECM8000 found HERE. Save target as ............
You require a soundcard calibration file. Information on creating one and using REW is found in the REW HELP FILES.
In the SETTINGS ICON routine there is an option to setup and use the soundcard calibration file.
These both must be in place before measuring with REW.
Old 03-10-07, 09:07 AM   #9
Alias: Jim
User: #6255
  vfrjim is offline
I did this and the results from a loopback cable to my Realtek, on-board soundcard is the posted graph. Does this look correct?
Old 03-10-07, 09:18 AM   #10
Alias: brucek
User: #6
When you use the loopback cable to check the results and effectiveness of your soundcard calibration file, you must (for this test only) clear the microphone/meter file, since the loopback cable obviously requires no calibration to be perfect.
So, if you have a proper soundcard cal file in place and forget to clear the microphone/meter calibration file and then perform the cable loopback test, you will get a graph that looks exactly like the inverse of the microphone/meter file. This is what I see in your graph (except you have substituted the C-Weight file instead - unclick it for this test). So, I would say you're good to go. To verify, do the loopback test with the mic/meter file cleared and the soundcard file in place.
Then you're ready to do measurements. Be sure to make your measurements with the mic/meter file loaded (and check the C-Weight box) so as to compensate for the meter.
When you post your graphs, the standard we use here is a 75dB target, with a horizontal scale of 15Hz to 200Hz and a vertical scale of 45dB to 105dB....
Note: The C-weight check box adds a C-Weight to the microphone readings outside the limits of the mic/meter file. So if the mic/meter file goes from 10Hz to 100Hz, then C-Weighting takes over (after that and before that) if the C-Weight box is checked. With no mic/meter file, then C-Weight takes over the entire range.
Old 03-10-07, 08:19 PM   #11
Alias: Jim
User: #6255
  vfrjim is offline
OK, so I was not able to get an "official" preliminary reading on my room with REW, but you get the idea with the TrueRTA graph. I now have many GIK Acoustics panels installed (14), with 2 TRI-Traps coming in on Monday (for my screenwall corners) in this small room (10'w x 15'L x 7'H). Attached is my "current" graph, opinions?
Thanks,
Jim
Old 03-10-07, 09:00 PM   #12
Alias: brucek
User: #6
Fairly smooth response. It might be a bit heavy between ~35Hz and 80Hz. An equalizer would help there, bit I guess it depends on how it sounds?
Old 03-10-07, 09:06 PM   #13
Alias: Jim
User: #6255
  vfrjim is offline
Thanks for the comments, It actually sounds pretty good, MUCH smoother then it was before, the BOOM is gone, much tighter and it hits lower. I will wait till my Tri-traps are installed before I take my BFD out of "bypass"mode and hook up my Midi interface.
Old 03-10-07, 10:35 PM   #14
Alias: brucek
User: #6
Yeah, you'll be surprised at how much the 15Hz to 25Hz range becomes more evident as you lower the ~35Hz and 80Hz even further. I suspect you'll need the BFD for that. You don't need to cut by much though. Everyone seems to agree that if you treat first and then EQ what's left, it's the best route to go...
Do you have the V1.4 firmware in your BFD or is it a FBQ2496 ?
Old 03-11-07, 08:12 AM   #15
Alias: Jim
User: #6255
  vfrjim is offline
I have a DSP1124P but have no clue on verifying the firmware version. I've had it for about a year if that means anything. If is not the 1.4 version, is it updatable? How? Thanks.
Jim
Old 03-11-07, 08:38 AM   #16
Alias: brucek
User: #6
The midi interface doesn't work with units of version 1.3
You would need to purchase a V1.4 ROM and install it in the BFD if you want the midi to work.
To find out your version, power up the unit while holding down the Filter Select button and read the Version # displayed.
Read this thread.
Not a big deal. I've never loaded filters with a midi yet. I just put them in by hand. Takes a second. Read them right off the REW screen.
Old 03-13-07, 10:42 AM   #17
Alias: Jim
User: #6255
  vfrjim is offline
Bruce, I am trying to use the Midi interface and it shows that it is sending the filter to the BFD but is there a way to verify this @ the BFD? Because the curve does not appear to change with the filters it is suggesting when I click on "find peaks" and create filters then send it to the BFD.
Thanks again,
Jim
Old 03-13-07, 11:26 AM   #18
Alias: brucek
User: #6
I'd probably wire the VC's in parallel and bridge the amp to make sure both drivers are always seeing the same level of gain.
Sure, you can look at the filters loaded in the BFD program manually. Look at the BFD manual. It spells out how to load and monitor your filters.
Ensure the IN/OUT green LED is on solid. This engages the filters.
It's best to play around with the BFD a while before worrying about the midi stuff. That way you get used to how it operates....
Old 03-18-07, 07:57 PM   #19
Alias: Jim
User: #6255
  vfrjim is offline
For the time being, I removed the BFD and did some experiments. The sub that I am using is a HSU VTK3 MK2 and did 2 graphs, one with one port open and the other with both open, here are the results. Opinions?
Old 03-18-07, 08:21 PM   #20
Alias: Derek
Vader's Avatar
Loc: Colorado
User: #1439
  Vader is online now
<picks jaw up off the floor>
Jim, that's your response before EQ'ing? Wanna trade houses? I would kill for that kind of response - especially since EQ'ing is not practical for me at the present time... I was gonna get a BFD and use REW to reprogram it, until I found out that a 75' USB or MIDI run was not feasible. So, until I get a laptop I'm kinda stuck (my response ain't that bad, but yours surely puts it to shame...
Peace... Vader
Louvre attendant: Sacre bleu! ze frame on ze Mona Lisa broke and ze only one left iz too small. Andre, bring me ze scissors!
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
The Overlook Theater - Not liable for injuries sustained while laughing.
Old 03-19-07, 07:34 AM   #21
Alias: Jim
User: #6255
  vfrjim is offline
Thanks for the kind words and yes, this is before EQ'ing but AFTER putting in all my acoustic treatments from GIK Acoustics (Thanks Glenn!). SO my question is, should I EQ at all? I value the experts opinions here.
Thanks.
Old 03-19-07, 07:57 AM   #22
Alias: terry
Loc: bathurst nsw australia
User: #1819
  terry j is offline
should you eq? Sure, why not??? The cost of the BFD would surely be minor compared to the acoustic treatments, and the best of both worlds is achieved by BOTH room treatment and eq. The vast majority of the people on this forum would only get the benefits of a 'half-done' job, namely use eq without adequate room treatment.
You don't want to be on the other side of that coin??? ie room treatment and no eq?? Go that little bit extra that very few of us reach, PROPER room treatment and PROPER eq and then very quickly post us graphs of your result along with pictures of your room and be an inspiration to us all!!!
even tho I'm not an expert I hope you value my opinion ha ha.
Old 03-19-07, 09:04 AM   #23
Alias: brucek
User: #6
terry and I will disagree here.
With a response like that why would you subject the signal to digitization, undigitization, noise, reduced dynamic range, phase issues, ground loops................................
Old 03-19-07, 05:07 PM   #24
Alias: terry
User: #1819
  terry j is offline
good point bruce. Is it really that bad?? If you had the DEQ would you consider it then?ie is there a point when you (bruce) would do it??
Old 03-19-07, 05:15 PM   #25
Alias: brucek
User: #6
Both my systems have a BFD in them since the response of both is horrible without it. When I see some of these rather perfect responses without equalization, I usually recommend not using one.
I don't mind in the crummy second system, but I've considered replacing the 1124P in the main system with a FBQ2496 - higher input levels, better dynamic range etc.. just better specs...
