| REW Forum what am i doing wrong?Discuss what am i doing wrong? in the Equalization | Calibration forum; what am i doing wrong? Good evening all ,
spent most of the evening trying to calibrate using REW. I started by using the EZ ... |
Views: 537 - Replies: 2
| what am i doing wrong? Good evening all , spent most of the evening trying to calibrate using REW. I started by using the EZ EQ of the Harman Kardon AVR 635 then proceeded to REW to flatten the response if needed. I followed the instructions carefully everything seemed to be fine but when i took measurement wel got a message that no peak needed to be worked on. I took another measurement got somewhat a slightly different graph. which is dipping at the begining. Not sure if tat's ok or not. Anything i am doing wrong? should i aim for 85DB target level instead ? Any help is more than welcome | ||||
| | #2 | ||||
| Re: what am i doing wrong? Set your graph limits to a vertical axis from 45dB to 105dB and the horizontal axis from 15Hz to 200Hz and a target to 75dB. Did you press the Find Peaks button? brucek | ||||
| | #3 | |||||
| Re: what am i doing wrong? Quote:
Good evening Bruce, Actually no i did not press the find peaks button silly me i will redo the test and post my result | |||||
