REW Forum
Lap Top Computer for REW
Discuss Lap Top Computer for REW in the Equalization | Calibration forum; Lap Top Computer for REW Can you guy's give me a recomendation for a Lap top Computer that can be purchased to use with the ...
Views: 606 - Replies: 6
Old 03-15-07, 05:41 PM   #1
Alias: koiman
Loc: Antioch, California
User: #5399
Since: Jan 2007
  koiman is offline
Can you guy's give me a recomendation for a Lap top Computer that can be purchased to use with the CM-140 and the REW program.
Thanks in advance.
Lee
Old 03-15-07, 11:44 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Lap Top Computer for REW
My understanding is that REW doesn’t take much computing power. Anything you get will do it. A few months ago I bought a used Compaq laptop that’s at least a few years old. I think it only has a Pentium III 1-gig processor with 256 RAM or something like that. Works just fine with REW and everything else I do. We typically recommend an outboard soundcard with REW, though.
Old 03-16-07, 12:09 AM   #3
Alias: koiman
User: #5399
Since: Jan 2007
  koiman is offline
Wayne,
Which external sound card do you suggest for the simplest set up.
Thanks,
Lee
Old 03-16-07, 02:17 PM   #4
Alias: Bob
Malice's Avatar
Loc: Lytham-St-Annes, UK
User: #304
  Malice is offline
http://www.hometheatershack.com/foru...nal-setup.html
| Sony KL-50W2 | Denon 3805 + POA-T10 Biamp| Denon 2900 | Pioneer 575-S | B&Ws 604s3/602s3/LCR600s3 in 7.1 | SVS PB12-ISD | BFD | Pinnacle Showcenter |Sky+(250GB) | Cables Scorpion & Mark Grant|
Bob - "Malice" was my Quake 2 CTF name
Old 03-16-07, 03:40 PM   #5
Alias: Wayne
Loc: Katy, Texas
User: #8
Lee,
The most commonly used cards are the Soundblaster MP3+, Soundblaster Live! 24-bit USB External and the M-Audio MobilePre-USB. The MP3+ seems to be discontinued and is getting a bit hard to find. However, I just found a couple of on-line vendors selling them for $20 or less, which is significantly less than I paid for mine about 6 months ago. The Soundblaster Live cost quite a bit more - it has a lot of features you don’t need for REW.
Old 03-16-07, 04:00 PM   #6
Alias: koiman
User: #5399
Since: Jan 2007
  koiman is offline
Wayne,
Could you give me the online website for the ones that you found.
Thanks,
Lee
Old 03-16-07, 07:10 PM   #7
Alias: Wayne
Loc: Katy, Texas
User: #8
Google is your friend.
http://www.google.com/search?sourcei...ter+mp3%2b
(You can skip Amazon - they don't have it.)
