REW Forum
Comparing SPL Meters
Discuss Comparing SPL Meters in the Equalization | Calibration forum; Comparing SPL Meters Hi Guys, Got my new CM-140 today and laid it side by side with my RS 33-2055 Digital. Played a ...
Views: 619 - Replies: 3
Old 03-16-07, 06:49 PM   #1
New Member
Alias: apbcom
Loc: Detroit
User: #4951
Since: Dec 2006
  apbcom is offline
Hi Guys,
Got my new CM-140 today and laid it side by side with my RS 33-2055 Digital. Played a number of test tones (sine waves) from 30 Hz to 5000 hz and noticed that the SPL levels at different frequencies vary as much as 20 db! Could this be a bad meter? Which one? I'll try to chart them out this weekend and see what the difference is. Any thoughts or am I missing something.
Old 03-16-07, 08:12 PM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Re: Comparing SPL Meters
apbcom wrote: View Post
Hi Guys,
It is not wise to measure 5000 Hz frequencies with straight sine waves. Only a small difference in mic placement can have a huge effect at those frequencies (small wavelength). One shouldn't measure any higher than ~100 Hz with sine waves.
Old 03-16-07, 09:05 PM   #3
New Member
Alias: apbcom
Loc: Detroit
User: #4951
Since: Dec 2006
  apbcom is offline
What would be the proper way to compare the two? I'd like to see how close or not they are in measuring.
Old 03-16-07, 09:28 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Comparing frequencies higher than 100-200 Hz is very difficult unless you know what you are doing. But for low frequencies you can just plug them to your computer and run a few REW sweeps. Plain sine waves are also ok there, although you should still place both mics side by side. Use the same weighting for both (C-weighting).
