| REW Forum Can I use this Mic?Discuss Can I use this Mic? in the Equalization | Calibration forum; Can I use this Mic? I have a Shure mic in which I can get the Fequency response graph from the Website is it possible ... |
Views: 625 - Replies: 9
| | #3 | ||||
| Re: Can I use this Mic? well I have a mixer so I can bring the mic to line level and above easily. I don't have a calibration file but figured I may be able to make one becasue I have a response graph of the micrphone from the manufacturer. Can I make a calibration file from this? | ||||
| | #4 | |||||
| Re: Can I use this Mic? Quote:
Pick a frequency value to be the zero point. i.e 1000Hz. and then construct the file from there as to how far below zero (or above each frequency might be). REW will interpolate the missing data between the points. i.e. 20.00 -15.00 25.20 -12.00 31.75 -10.00 40.00 -5.00 etc....... well you get the idea. Any values above the file, REW will extend. Save the file as a meter.cal file... brucek | |||||
| | #5 | |||||
I'm sure there are PC equivalents as well. Later, Mace | |||||
| | #6 | ||||
| Re: Can I use this Mic? Yeah, Actually alot of micrphones will have a frequency response graph avaialble for their mic's so this would be a good aaplication to have around. Does anybody know of a app similar to this for windows? I am surprised you guys don;t hava thread with different mic's and the Calibration graphs to go with them.. | ||||
| | #7 | |||||
We presently recommend the Behringer ECM8000 microphone with preamp or the Galaxy CM-140 SPL meter. We have calibration files available for them both on our downloads page. Equalization of subwoofers (which is what REW is used for mostly) require microphones (or very good quality SPL meters) to be able to accurately extend down to 5Hz. Many microphones are specifically tailored for voice and don't extend that low (I suspect your Shure is that way). Even when they do extend to very low frequencies, (such as in the case of the ECM8000 microphone), they require calibration professionally to get the values needed for the very low frequencies. Generally what the manufacturer will supply wouldn't be of much use in that regard. Below is the specification graph supplied by the manufacturer for the ECM8000. It extends to 60Hz. Below that is the professionally calibrated results graph shown to 5Hz of the cal file we provide when fed into REW software. Do you feel that any graph software could pull the calibration file from that specification graph? See the problem? SPECIFICATION GRAPH. ![]() ECM8000 PROFESSIONALLY CALIBRATED TO 5Hz. ![]() brucek | |||||
| | #9 | ||||
| Re: Can I use this Mic? It really depends on what you want to use REW for. If you want to test your subwoofer down to 20Hz for example and had a specification graph that went that low with enough resolution to create some data points, then it would be fine. brucek | ||||
| | #10 | ||||
| Re: Can I use this Mic? I thought it was for balancing the output of your speakers but now after reading alittle more I see it is not. Flat response is alot not really what I am looking for aswell according to other info I read. What about a personal HT system using a PC. 22" LCD screen full 5.1 surround sound DD.DTS..etc. How would one go about setting up this simple system for optimal sound? | ||||
