| REW Forum REW vs SpectraLABDiscuss REW vs SpectraLAB in the Equalization | Calibration forum; REW vs SpectraLAB Hi, I use these 2 software packages to get a good respons from my Adire Tumult subwoofer in my room. ... |
Views: 1147 - Replies: 11
| REW vs SpectraLAB Hi, I use these 2 software packages to get a good respons from my Adire Tumult subwoofer in my room. I also have the Behringer FBQ2496 and the Behringer EMC8000 mic. To my optinion, the disadvantage of REW is that you can only make 1 measurement and use this one for creating all your filters. I've noticed that the predicted respons is not exactly the same as the final real life respons. I would like to correct peak by peak, in stead of all at once. SpectraLAB is also a good way to measure your room. With this package and manually entering filters, I get a flatter respons than with REW. A few questions: 1. With SpectraLAB I use pink noise, not a sweep that REW uses. Is there a difference? 2. Does REW uses a C-curve correction when measuring the room? So is the target a C-corrected curve, or a flat curve? 3. In REW, can you start measuring at a higher frequency than 2 Hz? Let's say 10 or 15 Hz? Regards, Bart Last edited by krunk; 04-03-07 at 01:41 AM.. | ||||
| | #2 | |||||||
| Re: REW vs SpectraLAB What is SpectraLAB? I can’t find anything on it with Google. From the way you describe it, I assume it uses real-time analysis? The nice thing about REW is that you don’t have to endure the test signal running the whole time you are tweaking filters. Quote:
Regards, Wayne | |||||||
| | #3 | ||||
| Re: REW vs SpectraLAB I think it's SpectraPlus... and if it is, it ain't nearly as functional and robust as REW. I would suggest that if your measured response is not at least fairly close to the predicted response, then you may not be entering the filters correctly or your mic may not be stationary between measurements... or something else it going on. | ||||
| | #4 | |||||
| Re: REW vs SpectraLAB This is some more info about SpectaLAB. http://www.pmgrp.com/prod01.htm It's one of the four versions that is available. It's also the most complete one and quite solid software. Anyways, ![]() First point I understand that using pink noise can give interference at other frequencies, a sweep is just 1 frequency. So you may be right at that. Second point. I use a mic, not a SPL meter. But I understand that in that case, no correction is applied. Through? Third point. Do you have the option (somewere in the software or registry) to change the start frequency? Otherwise, this may be something for the next version? Quote:
The only thing that's left is phase respons. This could be good info to get your subwoofer alligned with the main speakers. Applying filters also change the phase, so some more info on this could be handy. Thanks for your answers so far. ![]() Bart | |||||
| | #5 | |||||||||
| Re: REW vs SpectraLAB Quote:
![]() Quote:
There’s no good reason I can think of to have the start frequency sweep of a sub adjustable. I suppose you have one? End frequency, sure, but start frequency?Quote:
Regards, Wayne | |||||||||
| | #6 | |||||||
The advantage is that you don't have to work with a predicted respons. But if the predicted respons is the same as the real respons, there is no issue. Quote:
10 Hz is a better startingpoint if you ask me. (I understand that the software doens't provide this, that's why I asked if it was possible to change the value on a different level like the registry) Also, a flexible starting point could be handy if you only want to measure the frequencies around the crossover frequency. You don't need a full sweep for that. Quote:
Thanks for you help so far. I'm just giving some feedback, please don't take this in a negative way. ![]() | |||||||
| | #7 | |||||
I'm not sure why this is such a big deal. If you only want to see from 10Hz on up, simply set your graph axis limits from 10Hz on up to however far you want. It's as if anything below 10Hz wasn't measured. You are only talking about a few seconds of extra sweep... it's not hurting a thing... ![]() | |||||
| | #8 | |||||||
![]() Personally I wish he had extended his chart below 10 Hz! The sweep is already programmed to extend an octave above your cut-off point, just to make sure you get a complete reading. No reason not to start “too low” for the same reason! Quote:
![]() Bottom line, there’s just no good reason to have an adjustable starting point for the sweep. None of the reasons I’m seeing here I would consider good reasons. (No offense I hope – you did ask for feedback! )Quote:
![]() Regards, Wayne | |||||||
| | #9 | ||||||||
| Re: REW vs SpectraLAB This is my respons. Tumult in a closed box, no boost and no smothing. Quite flat, only a dip around the 25Hz region. Quote:
I can set the distance of the sub on my reveiver, but I don't have a phase shift on my sub to change to overall phase. Whatever I do, I always have a small dip at the crossover point. But I'll do some more testing for this. Bart | ||||||||
| | #11 | ||||
| Re: REW vs SpectraLAB Yep... most IB and LLT subs will reach 10Hz.... some lower than that... and we have a lot of members with IB and LLT subs. Sure some of the response may be room gain, but the sub has to produce a signal for the room to have an effect on it. ![]() | ||||
| | #12 | |||||
Regards, Wayne A. Pflughaupt | |||||
