| REW Forum Does this plot look reasonable?Discuss Does this plot look reasonable? in the Equalization | Calibration forum; Does this plot look reasonable? The attached plot is that of my floorstanders. Does it look about right?... |
Views: 827 - Replies: 5
| | #2 | ||||
| Re: Does this plot look reasonable? Not bad. A few dips, but not bad. How did you measure it? Specifically, what mic? Our "normal" tools (i.e., RS and Galaxy SPL meters) aren't too accurate above a couple kHz or so... -- Otto | ||||
| | #3 | ||||
| Re: Does this plot look reasonable? I am just starting to play with Room EQ Wizard and I have an old RS analog meter that I bought 2-3 yrs ago. I might get a better mic depending on if I really needed one. Nick | ||||
| | #4 | ||||
| Re: Does this plot look reasonable? With an old RS SPL meter, I measured the floorstanders' output like a sub. Then I ran "full range" sweep (after recalibrating with "full range pink noise") to view the result after applying 6 filters. I thought someone said BFD for full range use would make the sound gritty. I was trying hard to hear the grit but did not find the sound to be gritty at all. Here's the plot: Nick | ||||
| | #5 | |||||
| Re: Does this plot look reasonable? Quote:
brucek | |||||
| | #6 | |||||
For whatever reason, I get valleys in the 170-550Hz range with my two sets of mains. Being able to EQ the mains in this frequency range helps to impart warmth and balance to the music without the boomy sound that one would get with a simple bass boost. EDIT: The hiss is inaudible if volume is off. The hiss was heard with the volume control at listening level of 75-80dB (est), and CD player stopped. But that's with one ear to the tweeter. Nick Last edited by MakeFlat; 05-28-07 at 12:35 PM.. Reason: revised freq range; also,see EDIT note at the bottom. | |||||
