| REW Forum External sound card questionDiscuss External sound card question in the Equalization | Calibration forum; External sound card question I have a chance to buy this M-Audio usb card..for $100 .... is this a card I can use with ... |
Views: 2180 - Replies: 5
| | #2 | ||||
| Re: External sound card question Yes, others have used this external soundcard successfully..... the nice part about it is that it has its own mic preamp with phantom voltage that can be used with the ECM8000 microphone.. brucek | ||||
| | #4 | ||||
| Re: External sound card question Yeah, you won't need an SPL meter if you have a "real" mic. Of course, an SPL meter is good for other things (setting levels, etc.). -- Otto | ||||
| | #5 | ||||
| Re: External sound card question I finally bought this M-Audio usb audio card...can I still proceed with it even though I don't have the mic..? I do have the digital RS meter.. since the meter has a mic on it is there a particular place on the card that it goes or just where it says 'mic'? | ||||
| | #6 | ||||
| Re: External sound card question I think you'll want to get it input on the 1/4" balanced inst/line input. Get an RCA to 1/4" TS connection, which is easily made and/or available at RS or perhaps Guitar Center. -- Otto | ||||
